Yesterday the solar installers came by, connected a LAN cable directly to my router and changed the config to not use the cellular card. Using the home-assistant-solaredge-modbus integration from github I copied the custom_components directory into my /config directory and installed the integration specifying my IP address and port 1502. All seemed to go well but no data flowed into HA and I am getting a connection refused error. My log shows this sequence every 30 seconds (default data retrieval interval):
pymodbus.exceptions.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.0.97:1502)]
2022-08-29 23:18:07.781 ERROR (MainThread) [pymodbus.client.sync] Connection to (192.168.0.97, 1502) failed: [Errno 111] Connection refused
2022-08-29 23:18:07.782 ERROR (MainThread) [custom_components.solaredge_modbus] Error reading modbus data
File "/config/custom_components/solaredge_modbus/__init__.py", line 195, in async_refresh_modbus_data
update_result = self.read_modbus_data()
File "/config/custom_components/solaredge_modbus/__init__.py", line 246, in read_modbus_data
self.read_modbus_data_inverter()
File "/config/custom_components/solaredge_modbus/__init__.py", line 570, in read_modbus_data_inverter
inverter_data = self.read_holding_registers(unit=self._address, address=40071, count=38)
File "/config/custom_components/solaredge_modbus/__init__.py", line 233, in read_holding_registers
return self._client.read_holding_registers(address, count, **kwargs)
File "/usr/local/lib/python3.10/site-packages/pymodbus/client/common.py", line 114, in read_holding_registers
return self.execute(request)
File "/usr/local/lib/python3.10/site-packages/pymodbus/client/sync.py", line 106, in execute
raise ConnectionException("Failed to connect[%s]" % (self.__str__()))
I have tried connecting to http://192.168.0.97:1502 with my browser and get a “refused to connect” error. I can ping the IP address successfully. The PN of my inverter ends in a 4 so it looks like I should have the ability to connect. Do I need to do something with the inverter itself to allow a connection? Any other ideas are welcome.
