Well that didn’t take long. The Error’s don’t seem to point to SolarEdge, but again it’s one of the last few things I did. The only other errors are around the Shelly Integration, but that is a native integration. Anything Stand out here?
Logger: homeassistant
Source: /usr/src/homeassistant/homeassistant/runner.py:138
First occurred: 7:39:35 PM (5 occurrences)
Last logged: 7:39:35 PM
Error doing job: Task exception was never retrieved: File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 222, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 210, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 672, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 639, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1980, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 127, in _send_heartbeat self._loop.create_task(self._writer.ping()) # type: ignore[union-attr]
Error doing job: Task exception was never retrieved: File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 222, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 210, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 672, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 639, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1980, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/client_ws.py", line 103, in _send_heartbeat self._loop.create_task(self._writer.ping())
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 715, in ping
await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 682, in _send_frame
self._write(header + message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 702, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
