SolarEdge integration install for the first time to monitor my new SE10000 inverter.
I get a list of 21 entities, but all are shown as “unavailable” except for two:
sensor.solaredge_current_power
sensor.solaredge_lifetime_energy
The inverter has consumption monitoring so all the sensors should be available?
Anyone have any ideas on why/how to fix?
Hi Stuart,
Did not find a resolution for the native Solaredge intergration. I went with the Solaredge Modbus custom instead, much better because it’s all local.
Here’s how to enable Modbus on your inverter:
Enable Wi-Fi on the inverter by switching the toggle switch on the inverter to “P” position for less than 5 seconds.
Connect to the inverter access point like you would any Wi-Fi network, the password is on the RHS of the inverter.
question after I have done all this do I have to do something with the switch to get the system reset per se or does it just time out…(the switch on the inverter)
