Im trying to connect my solark solar inverter, i have tried
which i believe is geared to the original inverters more and is supposed to connect via ip from the solark data logger.
ive also tried GitHub - pbix/HA-solark-PV: Home Assistant integration for the SolArk PV Inverter
i conected the solark to a waveshare rs485 to eth box (found out afterwards it will not support mod bus but other posts suggest this still works.
when i tried to test via modpoll i get polling slave, request timed out.
Do i need a different converter for my modbus?
