Solarman integration problem
Hi everyone. Ive been trying to integrate my deye hybrid inverter via solarman hacs integration. Connected fine but the inverter is giving out of the blue data. Tried to downgrade the solarman version to 1.4.3 i belive like internet suggested but with no luck. Data is crap or “unavailable”.
Latest home assistant
Any ideas? This lack of data is destroying my peace, and I really would like to move on with my life :slight_smile:
not using it myself (yet) but this fork/update of the Integration you mention above seems to be more “active” so might be worth a look
Thanx! Same thing gibberish data unfortunately. I wonder what’s the reason some have the problem some do not…Ill try the api way maybe it’ll work
FWIW, I just got a DEYE 10kW hybrid inverter a few days ago, and I managed to get the integration to work pretty easily. I started with the more commonly referenced integration from Stephan Joubert, but today I discovered the davidrapan fork and I do find the slight changes to be great.
In my case, the data seems accurate, but the stick seems to go offline roughly every 5 minutes for about a minute or more. I haven’t yet done enough investigating to determine what the cause is.
Firmware version: LSW3_32U_5406_1.07
Hi try version 1.4.3 people report it is most reliable as for solarman.
And the deye_sg04lp3.yaml in the config fixed my problem.
Geting the right data now.
Next thing is to operate the charging and discharging. I dont think that solarman has that kind of options.
Do You get all the data from davidrapan ? I’m missing daily production and daily charge and discharge.
I seem to be getting all the data that I should be. I do have values for Today’s Production, Today’s Battery Charge, and Today’s Battery Discharge.
What yaml are You using in the config?
I’m just using the default deye_hybrid.yaml
Hello guys, please take a note that you should use sensors prefixed with Total (and not Today’s) for Energy dashboard. :wink:
Hey David.
I have a 6Kw Hybrid with some storage
I have been using it like that for a couple of months, and it looked ok. I just added some microinverters to the GEN port.
Total production looks like is only taking into account the solar mppt ports and the “Total grid production” is decreasing during the day but increasing during the night (I am off grid for these tests no grid in or out). Do you know where can I get the total?
What about the Total Generation entity? Does it show any meaningful data?
