Solarman Inverter: UNKNOWN, again
I use a solarman deye 10 kW inverter which I had already integrated using the custom components from HACS and fixed the yaml file so it didn’t have “unknown” as a value and it worked.
It was connected correctly but then the power went out and it still gave the same problem (the inverter is online). I then tried unintegrating my devices and re-copying the deye_hybrid.yaml file as it was before but it didn’t fix it. How can I do? Thank you
