⚡ Solarman Stick Logger by David Rapan
Hi there, as I had many issues running the integration from Stephan I decided to create my own overhaul which is somehow based on the original one.
Perhaps there will be those here who will also find my polished version useful.
This version is much more stable, has more frequent updates (but in different intervals for different sensors, when feature enabled), supports configuration of the device, uses asynchronous pysolarmanv5 (dynamically creates request sets according sensor descriptions in definition profile) and contains many more fixes, improvements and up to date features of :house_with_garden: Home Assistant.
Read more info about changes on the repo and please read carefully before you decide to try it. :wink:
As there are many changes I decided to publish them as separate project.
:high_voltage: Solarman Stick Logger
🠶 Signpost
Have fun!
Did you consider collaborating with Stephan?
Hi, thank you for your question.
I have, of course, at least from the start but when I at the end ended up writing again from ground up whole inner logic as well the way how it is integrated with HA I decided not to go through that route (at least for now) for the following reasons:
  • I can imagine that Stephan would really be happy from a pull request which changes the whole thing
  • Potential overhead of integrating the changes (the proper way)
  • I’m really not a fun person to work with (trust me bro)
But that does not mean it can’t happen in the future. :wink:
I’m surely open for it. I even indirectly did let him know in his repo so I’m sure if he would be interested he would say so. :wink:
Thanks again and as always have fun! :slight_smile:
Thanks for the honesty! :joy:
Always! :smiley:
I can highly recommend HA-Solarman by David Rapan!
Updated Solarman 1.4.3 from Stephen Joubert with this one and there are more useful sensors and it is som much faster updating the values.
Great work and brilliant support!
Many thanks!
Hi @davidrapan,
Thank you for your work on this, i got it working in no time.
I do have a question though, what is the difference between ‘PV Power’ and ‘Load Power’ ?
Load power seems to reflect the values that my inverter displays, PV power is PV1 and PV2 combined but im not sure which i should be using to display what is actually available to my home.
Also, im curious which sensors you would recommend using on the energy dashboard.
Much thanks :slight_smile:
Hi @jonathang, Load Power shows how much power your workplace/household really consumes and PV Power shows how much power is produced.
Have strange behavior with Deye Cloud conflict:
When connecting Solarman via my WiFi logger to HA - my Deye battery RW-M5.3 Pro in cloud goes offline. And vice versa.
And there is no Deye battery type in integration, showing as Pylontech…
Is it battery type conflict of serial baudrate limit conflict…
Logger SN 29*
sensor List: 5406
LSW3_32U_5406_1.0B
Last fw version .07 (.06 was the same)
Have to use rs485 so…
Discussion on the previous post ^^: Deye Battery Offline in Cloud
David, thanks for putting together this great integration. My family recently installed a Deye 10kW hybrid inverter at their off-grid site, and your integration has helped me access all the data I needed to implement some smart management in Home Assistant. However, they now just had a generator installed, and I’m not sure of how I should be interpreting the data. I’ve always been using the “Power” sensor to read how much total power the house is consuming (sensor.deye_10kw_inverter_power), but when the generator is running and charging the battery, this figure turns negative. I’ve tried to find a different sensor that only shows the power being consumed by the loads, but I can’t see one. I expected that the “L1 Output Power” sensor would be the one I need, but this sensor actually shows the same negative value. I also thought of the “Load Power”, but this shows a very small value that doesn’t seem to correspond to anything.
I’m using the default deye_hybrid.yaml configuration. The Solarman app seems to be showing the correct values, so does this indicate that perhaps this configuration file is not quite right for my inverter? My inverter has 3 MPPTS, and there doesn’t seem to be a 3 MPPT version in the other config files. How do I go about getting the correct values? I’m very new to the Solarman, so I don’t yet know much about the inner workings. Is it possible that the installers haven’t configure something correctly?
I’m including some screenshots to show what’s happening:
ps. The integration is showing a value for “Micro-Inverter Power” but we don’t actually have any micro-inverters. It seems to be showing the generator power.
Hi @dzerovibe!
  • Power sensor shows input/output power of the inverter itself. Picture provided shows combined input of PV and Generator flowing into the battery (and to the Load) and looks correct.
  • Load Power sensor should give you Consumption value visible on the picture from the Solarman App and is indeed wrong! Unless Solarman App displays Consumption as sum of Load Consumption, Inverter Consumption and AC/DC Conversion losses. In that case it would ± match observed values!
  • Micro-Inverter Power is interchangeable with Generator Power, yes. (It’s just additional input of the inverter and in your case you have there output of the generator)
It’s really hard to tell what could be wrong here. Can you please give me an exact model and type of the device so i can look into it?
:wink:
Recently migrated from “other” Solarman integration to this one…very easy to do (with info on GitHub Discussions), kept all old data, etc so thanks for all the work. I’m using a custom parameters file (have been for ages) and while it’s on my list to migrate to one of the built-in parameters it’s not near top of the list for now.
In the other Solarman it was possible to configure one Inverter/logger multiple times using different parameter files but with this one the integration tells me that the IP is already configured which of course it is…question is then if there is a way to circumvent this and configure the same inverter/logger more than once (so I can leverage one of the build in parameters along with my custom one)?
Hi @Gav_in,
Unfortunately, there is no easy way to do this. Device configuration sets device_unique_id from serial number (not from IP) and thus won’t allow you to setup multiple devices using the same serial number.
Manual workaround does exist but involves direct edit of /homeassistant/.storage/core.config_entries by duplicating existing entry of already configured device and changing entry_id and unique_id of this duplicate accordingly. Or by adding second device with some made up serial number and then changing serial number of that entry.
Cheers David…like the sound of the second option, might have a look at that…thank you!
I noticed this new version asks me battery voltage and cycles. Since I have the SOFAR HV modules for battery which have whatever Voltage (depends on number of modules and I don’t even know it) … is this a dangerous setting? Can it cause a problem? (I run a SOFAR HYD KTL-20kW-PH3).
Also: I notice the yaml for the g3 sofar inverters (I think that’s the one I’m suppsoed to run for my model according to the remarks in the yaml) has entries PV1 and PV2 … are these the MPPT’s? I wonder because the 20kW has three MPPTs, in which case there should be a PV3? But maybe I interpret this wrong … I try to find a documentation to all the parameters of the solarman LSE-3 attached to my device (serial starting with 29, firmware LSW3_15_MQTT_270A_1.10).
Hi @voon, you can totally ignore those two as they are just for additional estimation of Battery SOH and nothing else.
And yes PV = MPPTs so yeah you should have PV3 sensors too. It’s very easy to add them
Thanks … I tried to be clever without being any HA person, and copied the PV2 lines in the yaml to add PV3 ones with the pv3 hex registers … at least that gets me PV3 now displayed. Not sure if it works, as the inverter is not yet connected to the solar modules on the roof :slight_smile:
Yes, that should do it. :wink:
Great, thanks … I will see. Does anyone know if we can feed Values from Soalrman into the “Energy” display of HA? I mean momentary values, updated within 5 secs etc … to generate a beautiful energy flow diagram there. Since my inverter isn’t running yet and most values display 0, I wonder if anyone has done that?
