SolaX API Entity Configuration
I am completely new to Homeassistant (like 4 weeks or so)
I want to configure all Energy Entities for the Energy dashboard.
I have given them the energy Class and the total_increasing state.
After that configuration nothing works anymore.
Here my Code:
"""Solax cloud."""
from __future__ import annotations
from datetime import datetime
from homeassistant.components.sensor import (
    SensorDeviceClass,
    SensorEntity,
    SensorEntityDescription,
from homeassistant.config_entries import ConfigEntry
from homeassistant.const import PERCENTAGE, UnitOfPower
from homeassistant.core import HomeAssistant
from homeassistant.helpers.device_registry import DeviceEntryType, DeviceInfo
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.update_coordinator import CoordinatorEntity
from .const import DOMAIN
from .coordinator import solaxcloudCoordinator
ISSUE_PLACEHOLDER = {"url": "/config/integrations/dashboard/add?domain=solaxcloud"}
async def async_setup_entry(
    hass: HomeAssistant,
    entry: ConfigEntry,
    async_add_entities: AddEntitiesCallback,
) -> None:
    """Add Solax cloud entry."""
    coordinator: solaxcloudCoordinator = hass.data[DOMAIN][entry.entry_id]
    assert entry.unique_id
    unique_id = entry.unique_id
    async_add_entities(
        SolaxCloudSensor(unique_id, description, coordinator)
        for description in SENSOR_TYPES
class SolaxCloudSensor(CoordinatorEntity[solaxcloudCoordinator], SensorEntity):
    """Representation of a Solax cloud sensor."""
    def __init__(
        self,
        unique_id: str,
        description: SensorEntityDescription,
        coordinator: solaxcloudCoordinator,
    ) -> None:
        """Initialize the sensor."""
        super().__init__(coordinator)
        self.entity_description = description
        self._attr_unique_id = f"{unique_id}_test_{description.key}"
        self._attr_device_info = DeviceInfo(
            identifiers={(DOMAIN, unique_id)},
            entry_type=DeviceEntryType.SERVICE,
    @property
    def native_value(self) -> datetime | None:
       #print("called")
       """Return the state of the sensor."""
       return self.coordinator.data.get(self.entity_description.key)
SENSOR_TYPES = [
    SensorEntityDescription(
        key="inverterSn",
        name="Inverter serial",
        translation_key="inverter_serial",
        key="sn",
        name="Pocket serial",
        translation_key="pocket_serial",
        key="ratedPower",
        name="Inverter size",
        translation_key="inverter_size",
        device_class=SensorDeviceClass.POWER,
        native_unit_of_measurement=UnitOfPower.KILO_WATT,
        key="idc1",
        name="MPPT1 current",
        translation_key="mppt1_current",
        device_class=SensorDeviceClass.CURRENT,
        native_unit_of_measurement="A",
        key="idc2",
        name="MPPT2 current",
        translation_key="mppt2_current",
        key="vdc1",
        name="MPPT1 voltage",
        translation_key="mppt1_voltage",
        device_class=SensorDeviceClass.VOLTAGE,
        native_unit_of_measurement="V",
        key="vdc2",
        name="MPPT2 voltage",
        translation_key="mppt2_voltage",
        key="iac1",
        name="AC phase 1 current",
        translation_key="ac_phase1_current",
        key="vac1",
        name="AC phase 1 voltage",
        translation_key="ac_phase1_voltage",
        key="acpower",
        name="AC Power",
        translation_key="ac_power",
        native_unit_of_measurement=UnitOfPower.WATT,
        key="temperature",
        name="Inverter Temperature",
        translation_key="inverter_temperature",
        device_class=SensorDeviceClass.TEMPERATURE,
        native_unit_of_measurement="°C",
        key="yieldtoday",
        name="Yield today",
        translation_key="yield_today",
        device_class=SensorDeviceClass.ENERGY,
        native_unit_of_measurement=UnitOfEnergy.KILO_WATT_HOUR,
        state_class=SensorStateClass.TOTAL_INCREASING,
        key="yieldtotal",
        name="Yield total",
        translation_key="yield_total",
        key="feedinpower",
        name="Feedin Power",
        translation_key="feedin_power",
        key="powerdc1",
        name="MPPT1 power",
        translation_key="mppt1_power",
        key="powerdc2",
        name="MPPT2 power",
        translation_key="mppt2_power",
        key="pac1",
        name="AC phase 1 power",
        translation_key="ac_phase1_power",
        key="pac2",
        name="AC phase 2 power",
        translation_key="ac_phase2_power",
        key="pac3",
        name="AC phase 3 power",
        translation_key="ac_phase3_power",
        key="iac2",
        name="AC phase 2 current",
        translation_key="ac_phase2_current",
        key="iac3",
        name="AC phase 3 current",
        translation_key="ac_phase3_current",
        key="vac2",
        name="AC phase 2 voltage",
        translation_key="ac_phase2_voltage",
        key="vac3",
        name="AC phase 3 voltage",
        translation_key="ac_phase3_voltage",
        key="fac1",
        name="AC phase 1 frequency",
        translation_key="ac_phase1_frequency",
        device_class=SensorDeviceClass.FREQUENCY,
        native_unit_of_measurement="Hz",
        key="fac2",
        name="AC phase 2 frequency",
        translation_key="ac_phase2_frequency",
        key="fac3",
        name="AC phase 3 frequency",
        translation_key="ac_phase3_frequency",
        key="feedinenergy",
        name="Feedin energy",
        translation_key="feedin_energy",
        key="consumeenergy",
        name="Consume energy",
        translation_key="consume_energy",
        key="uploadTime",
        name="Last cloud upload",
        translation_key="upload_time",
        device_class=SensorDeviceClass.TIMESTAMP,
        key="batVoltage",
        name="Battery voltage",
        translation_key="battery_voltage",
        key="batCurrent",
        name="Battery current",
        translation_key="battery current",
        key="temperBoard",
        name="Battery temperature 1",
        translation_key="battery_temperature_1",
        key="surplusEnergy",
        name="Surplus energy",
        translation_key="surplus_energy",
        key="chargeEnergy",
        name="Charge energy",
        translation_key="charge_energy",
        key="dischargeEnergy",
        name="Discharge energy",
        translation_key="discharge_energy",
        key="acenergyin",
        name="Grid energy in",
        translation_key="grid_energy",
        native_unit_of_measurement=UnitOfEnergy.KILO_WATT_HOUR,,
        key="pvenergy",
        translation_key="pv_energy",
        key="soc",
        name="State of charge",
        translation_key="soc",
        device_class=SensorDeviceClass.BATTERY,
        native_unit_of_measurement=PERCENTAGE,
        key="battemper",
        name="Battery temperature 2",
        translation_key="battery_temperature_2",
        key="veps1",
        name="EPS phase 1 voltage",
        translation_key="eps_phase1_voltage",
        key="veps2",
        name="EPS phase 2 voltage",
        translation_key="eps_phase2_voltage",
        key="veps3",
        name="EPS phase 3 voltage",
        translation_key="eps_phase3_voltage",
        key="ieps1",
        name="EPS phase 1 current",
        translation_key="eps_phase1_current",
        key="ieps2",
        name="EPS phase 2 current",
        translation_key="eps_phase2_current",
        key="ieps3",
        name="EPS phase 3 current",
        translation_key="eps_phase3_current",
        key="peps1",
        name="EPS phase 1 power",
        translation_key="eps_phase1_power",
        key="peps2",
        name="EPS phase 2 power",
        translation_key="eps_phase2_power",
        key="peps3",
        name="EPS phase 3 power",
        translation_key="eps_phase3_power",
        key="epsfreq",
        name="EPS frequency",
        translation_key="eps_frequency",
        key="batcycle",
        name="Battery cycle count",
        translation_key="batcycle",
And The Problem:
The entity gets unavailable
Edit: All Entitys of The Solax Integration get unavailable
Edit 2:
The Logs show following problem:
Logger: homeassistant.config_entries
Quelle: config_entries.py:640
Erstmals aufgetreten: 12:03:05 (1 Vorkommnisse)
Zuletzt protokolliert: 12:03:05
Error setting up entry Inverter Schnittstelle 1 for solax_cloud
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1272, in _load_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1304, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/solax_cloud/sensor.py", line 147, in <module>
    state_class=SensorStateClass.TOTAL,
NameError: name 'SensorStateClass' is not defined. Did you mean: 'SensorDeviceClass'?
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 640, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/solax_cloud/__init__.py", line 56, in async_setup_entry
    await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2278, in async_forward_entry_setups
    await integration.async_get_platforms(platforms)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1185, in async_get_platforms
    import_future.result()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1173, in async_get_platforms
    platforms.update(self._load_platforms(platform_names))
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1098, in _load_platforms
    platform_name: self._load_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1292, in _load_platform
    raise ImportError(
        f"Exception importing {self.pkg_path}.{platform_name}"
    ) from err
ImportError: Exception importing custom_components.solax_cloud.sensor
