Solax Integration with PocketLan
Hi Guys,
we are in the process of buying an photovoltaic power plant with SOLAX X3 Inverter. Currently including a PocketLAN Adapter. Before buying, I try to find out, the best way how to integrate the SOLAX Inverter into Home Assistant.
I already found this article describing how to integrate via Cloud and via PocketWifi. More over I found the SolaX Inverter Modbus Addon which integrates via Modbus / USB-Stick. But I did not found any direct integrations using Pocket Lan Adapter.
Now I’m struggling, if I may should change my order to PocketWifi instead of PocketWifi.
Do you have any suggestions for me?
Thanks a lot
Martin
Finally have you got PocketLAN or changed to PocketWifi?
I’m just looking for information about the ingetration with PocketLAN.
Hi, I have an X1 hybrid with pocket lan 2.0. Did you get it working?
