Solax X1-Hybrid-G3 local Rest API conf
I have a Solax X1-Hybrid-G3 (with fw version 2.033.20) and after changing the password in the Pocket Wifi Pen from “admin” (default) to something else, the setup I had (reverse proxy setup) was no longer connecting, as the raspberry pi at moment of the connection to the Pocket Wifi Pen was no longer able to add user/pass during authentication.
I read that we could use Local Rest API access to the inverter here https://community.home-assistant.io/t/solax-x1-hybrid-g4-local-cloud-api/506172 and here https://community.home-assistant.io/t/solax-x1-boost-air-mini-local-data/535197 and at moment I have it connected successfully (from HA directly to the Solax X1-Hybrid-G3) but I’m not able to map some attributes like TodayFeedIn, TodayConsumed and TodayEnergy to be able to setup the Energy Dashboard correctly.
I’m sharing the mapping I made so far for the Local Rest API Data array for the X1-Hybrid-G3 below - does anyone has any working Local Rest API configuration for the X1-Hybrid-G3 or at least know how to get the attributes above to setup the Energy Dashboard correctly?
From the inversor I can confirm that OutputGridToday is mapped with Data[8], OutputGridTotal is mapped with Data[9], FeedInTotal is mapped with Data[41] and ConsumeTotal is mapped with Data[42].
Thanks in advance for the help.
Position	Data	X1-Hybiyd-G3 ("ver":"2.033.20")
0	3.4
1	3.4
2	153.2
3	238.0
4	5.6
5	235.7
6	1308
7	32
8	4.6	    OutputGridToday
9	9595.9	OutputGridTotal
10	19
11	526
12	812
13	0.00
14	0.00
15	0
16	0
17	0.0
18	0
19	0.0
20	0
21	0
22	0.0
23	0.0
24	0.0
25	0.0
26	0.0
27	0.0
28	0.0
29	0.0
30	0
31	0
32	0
33	0
34	0
35	0
36	0
37	0
38	0
39	0
40	0
41	5150.14	FeedInTotal
42	8081.97	ConsumeTotal
43	0
44	0
45	0
46	0
47	0
48	0
49	0
50	50.03
51	0
52	0
53	0.0
54	0.0
55	0
56	0.00
57	1
58	0
59	0
60	0.00
61	0
62	0
63	0
64	0
65	0.00
66	0
67	0
68	2
69	1
70	26
71	1.00
72	4000
73	100
74	10
75	20.00
76	20.00
77	0
78	0
79	0
80	0
81	0.0
82	0.0
83	9486.0
84	0.0
85	0
86	0
87	0
88	0
89	0
90	0
91	0
92	0
93	0
94	0
95	0
96	1
97	1
98	0
99	0
100	0.00
101	0.00
102	1
103	16
104	0.0
105	0.0
106	0
Did you manage to progress this? I am currently trying to get my X1 hybrid G3 connected via modbus using the integrated ethernet port, but struggling! Have used the web api for a while to get data, but keen to be able to improve this
