I struggled a lot to get the solax inverter to work in Home Assistant. Partially because of advanced discriptions in this community and because solax does not publicly share what each value in the json file means. Some minor problems occured only after a longer use period. These issues have been resolved. For Instance:
- Solax Inverter sometimes reporting
0
as total energy produced. - 16 bit limit (max value
65535
) of total energy produced loops around, supposed loop counter is at Data point[23]
(might not be correct, i will update once it loops again).
This is specifically for the Solax X3 MIC G2.
My Local IP Adress is http://192.168.178.25
replace it with yours.
My Registration No. is SPXQ3XKSLGP
You can copy this as is into your configuration.yaml file. You only need the local IP adress of your Solax wifi/LAN USB Module and the Registration No.
#solaxlocalbegin
- platform: rest
authentication: digest
scan_interval: 20
resource: http://192.168.178.25/
payload: "optType=ReadRealTimeData&pwd=SPXQ3XKSLGP"
method: POST
headers:
X-Forwarded-For: 5.8.8.8
json_attributes:
- type
- SN
- ver
- Data
- Information
value_template: "OK" # dummy value, not used; avoids the "State max length is 255 characters" error
#solaxlocalend
# curl -d "optType=ReadRealTimeData&pwd=SPXQ3XKSLGP" -X POST http://192.168.178.25
template:
- sensor:
#solaxlocalbegin
- name: solax_local
state: >
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ now().strftime("%H:%M:%S") }}
{% else %}{{ (states('sensor.solax_local')) }}{% endif %}
attributes:
sn: >-
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ (state_attr('sensor.solax_rest_local', 'sn')) }}
{% else %}{{ (state_attr('sensor.solax_local', 'sn')) }}{% endif %}
ver: >-
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ (state_attr('sensor.solax_rest_local', 'ver')) }}
{% else %}{{ (state_attr('sensor.solax_local', 'ver')) }}{% endif %}
type: >-
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ (state_attr('sensor.solax_rest_local', 'type')) }}
{% else %}{{ (state_attr('sensor.solax_local', 'type')) }}{% endif %}
Data: >-
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ (state_attr('sensor.solax_rest_local', 'Data')) }}
{% else %}{{ (state_attr('sensor.solax_local', 'Data')) }}{% endif %}
Information: >-
{% if not state_attr('sensor.solax_rest_local', 'sn') == "XXXXXXX" %}{{ (state_attr('sensor.solax_rest_local', 'Information')) }}
{% else %}{{ (state_attr('sensor.solax_local', 'Information')) }}{% endif %}
- name: "Solax Energy today"
unit_of_measurement: "kWh"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[24] / 10 }}"
device_class: energy
state_class: total
icon: mdi:solar-panel
- name: "Solax Energy Total"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[22] / 10 + state_attr('sensor.solax_rest_local', 'Data')[23]*6553.5}}" #22 or 68, 16 bit cannot be higher than 65535 --> loops around, supposedly 23 is loop counter
availability: "{{ state_attr('sensor.solax_rest_local', 'Data')[22] > 1 }}" #sometimes the inverter report 0 as a values, this messes up HA, this solves the problem
state_class: total_increasing
icon: mdi:chart-line
- name: "Solax DC Voltage 1"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[9] /10 | float }}"
unit_of_measurement: "V"
device_class: "voltage"
- name: "Solax DC Voltage 2"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[10] /10 | float }}"
- name: "Solax DC Current 1"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[12] / 10 }}"
unit_of_measurement: "A"
device_class: "current"
- name: "Solax DC Current 2"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[13] / 10 }}"
- name: "Solax DC Power 1"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[15] }}"
unit_of_measurement: "W"
device_class: "power"
- name: "Solax DC Power 2"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[16] }}"
- name: "Solax DC Power Total"
state: "{{ (state_attr('sensor.solax_rest_local', 'Data')[15]) + (state_attr('sensor.solax_rest_local', 'Data')[16]) }}"
- name: "Solax Power Efficiency"
state: "{{ ((state_attr('sensor.solax_rest_local', 'Data')[78] | float) /
((state_attr('sensor.solax_rest_local', 'Data')[15] | float) +
(state_attr('sensor.solax_rest_local', 'Data')[16] | float)) * 100) | round(1) }}"
unit_of_measurement: "%"
device_class: "power_factor"
- name: "Solax AC Output Voltage"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[0] / 10 }}"
- name: "Solax AC Current"
state: "{{ (state_attr('sensor.solax_rest_local', 'Data')[3] / 10) + (state_attr('sensor.solax_rest_local', 'Data')[4] / 10) + (state_attr('sensor.solax_rest_local', 'Data')[5] / 10)}}"
- name: "Solax AC Power"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[78] }}"
icon: mdi:power-socket-de
- name: "Solax AC Frequency"
state: "{{ state_attr('sensor.solax_rest_local', 'Data')[18] / 100 | float }}"
unit_of_measurement: "Hz"
device_class: "frequency"
icon: mdi:music-clef-treble
- name: "Solax Inverter Operation Mode"
state: >
{% if state_attr('sensor.solax_local', 'Data')[21] == 0 %}Waiting
{% elif state_attr('sensor.solax_local', 'Data')[21] == 1 %}Checking
{% elif state_attr('sensor.solax_local', 'Data')[21] == 2 %}Normal
{% elif state_attr('sensor.solax_local', 'Data')[21] == 3 %}Off
{% elif state_attr('sensor.solax_local', 'Data')[21] == 4 %}Permanent Fault
{% elif state_attr('sensor.solax_local', 'Data')[21] == 5 %}Updating
{% elif state_attr('sensor.solax_local', 'Data')[21] == 6 %}EPS Check
{% elif state_attr('sensor.solax_local', 'Data')[21] == 7 %}EPS Mode
{% elif state_attr('sensor.solax_local', 'Data')[21] == 8 %}Self Test
{% elif state_attr('sensor.solax_local', 'Data')[21] == 9 %}Idle
{% elif state_attr('sensor.solax_local', 'Data')[21] == 10 %}Standby
{% else %}I dont know{% endif %}
- name: "Solax Inverter Nominal Power"
state: "{{ state_attr('sensor.solax_rest_local', 'Information')[0] | float | round(0) }}"
unit_of_measurement: "kW"
- name: "Solax Module SN"
state: "{{ state_attr('sensor.solax_rest_local', 'sn') }}"
- name: "Solax module fw version"
state: "{{ state_attr('sensor.solax_rest_local', 'ver') }}"
# - name: "Solax type"
# state: "{{ state_attr('sensor.solax_rest_local', 'type') == 3 %}X1Hybrid-G3 }}"
- name: "Solax Inverter SN"
state: "{{ state_attr('sensor.solax_rest_local', 'Information')[2] }}"
- name: "Solax Inverter Information"
state: "{{ state_attr('sensor.solax_rest_local', 'Information') }}"
- name: "Solax Inverter Data"
state: "{{ state_attr('sensor.solax_rest_local', 'Data') }}"
#solaxlocalend
To check if your Solax wifi/LAN USB Module is connected you can use the following command in Command Prompt or any other Terminal:
It will return something like this, if everything works:
{"sn":"SPXQ3XKSLGP","ver":"3.006.04","type":16,"Data":[2373,2357,2359,4,4,6,44,25,6,4566,2464,0,1,2,0,72,53,0,4997,4996,4999,2,2625,1,561,10000,42,38,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,76,0,1,5,1,0,13937,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"Information":[10.000,16,"MC540TI6275259",8,1.17,0.00,1.13,1.01,0.00,1]}
Have fun.
