Thank you, Francis, absolutely. Hit me up on the repo!
Iāve put forward my repo (on 4.0.22) for inclusion in HACS. Thereās a massive backlog, so I expect it will take a while - there are requests at least three weeks old in the queue.
In the meantime, so as not to slow down my submission when it reaches the front of the queue, Iāll start a new branch now, and cherry-pick some of the 4.0.23 changes:
- The fix to state_class= SensorStateClass.TOTAL
- The improved handling of error codes
- If polling api fails keep using current data
Iām inclined to leave the API counter logic intact (as it currently is in place in 4.0.22
Iāll update readme, and, in particular, include randomisation in fetch logic.
Iām in the same boat, but you can add a second integration instance for this and then select both in Energy dashboard.
But this is probably a subject more to be discussed at Open-Meteo Solar Forecast - #3 by elRadix Itās working OK for me, looks promising.
Question for anyone who has been around for a while - any idea why the automatic polling was removed from ozieeās Solcast Service?
I found when it was removed - it was last in 3.0.47 - around May last year. Does anyone recall any conversation around why?
Given the issues around randomising scheduling, Iām trying to understand if it is worth re-including scheduling in the integration with randomisation, and the API counter, and a warning that if you restart HACS, youāll probably hit your limit for that day (which, presumably, is no big deal).
Thanks in advance for any advice you can share.
This was probably due to the decrease in API polling quota for hobbyists from 50 to 10 API calls a day. As one can hardly spread 10 calls across 24 hours, it was the right decision to leave the polling up the to the users. Everyone should prioritize those 10 calls as they see fit. HA offers more than enough capabilities for scheduling.
With some on only 10 api calls per day and others on 50 if I recall the suggestion was to push to a local automation running the service, which is what I have. Mine runs every half hour during the day (on an offset of x minutes into each half hour), and every 2h after dark. That sits me in inside my 50.
As a quick hotfix to the randomness it might just be worth adding a random 0-10min sleep timer on the update API call. Then anyone using the new version automatically has it.
Itās nothing fancy. Runs at 22 and 52 mins past each hour in day, and every 2nd hour at 26 past at night. If Iām at API limit already it does not run.
alias: "Energy: Solcast API update"
description: "Energy: Solcast API update"
- platform: time_pattern
minutes: "22"
minutes: "52"
hours: /2
minutes: "26"
condition:
- condition: numeric_state
entity_id: sensor.solcast_pv_forecast_api_used
below: sensor.solcast_pv_forecast_api_limit
- choose:
- conditions:
- condition: sun
before: sunset
after: sunrise
- condition: trigger
id:
- "1"
sequence:
- service: solcast_solar.update_forecasts
data: {}
- conditions:
- condition: sun
before: sunrise
after: sunset
id:
- "2"
sequence:
data: {}
mode: restart
I just added a random delay into the actions before it does anything like this :
delay: "{{ (range(0, 1)|random|int) }}:{{ (range(1, 30)|random|int) }}:00"
I do note the repository has disappeared in the last few days.
Sorry, I am trying to follow along, which repo should we be migrating to?
It seems that the integration no longer exists. The link on Github leads nowhere. Does anyone know what happened?
You will find the answer above.
I uninstalled the old solcast repo, rebooted etc. Then added the new BJreplay however i cant get it to install in intregrations to configure it. I can see i have downloaded version 4.0.25 under Hacs frontend but i can not seems do anything else. what am i doing wrong.
I have solved my own question. However it may help others i added it to my Hacs through the link. It added it as a plugin not an integration, i deleted it and reinstalled it as an integration
Iām in the same situation but your statement is not true - open-meteo does support multiple orientations - just add all your roofs (add your 1st set of panels then go back to the integration and add additional service then add your second etc)
Yes this was the reason for auto polling being removed ā¦ the growing discrepancy between hobbyists with a different api cap - so Oziie posted something somewhere at the time that they would leave it to the end users to poll.
In case it helps to someoneā¦
This code calculates when to update solcast data using limited API calls (10 in this case):
alias: Solcast update
description: ""
value_template: >-
{% set nr = as_datetime(state_attr('sun.sun','next_rising')) | as_local %}
{% set ns = as_datetime(state_attr('sun.sun','next_setting')) | as_local
%} {% set api_request_limit = 10 %} {% if nr > ns %}
{% set nr = nr - timedelta(hours = 24) %}
{% endif %} {% set hours_difference = (ns - nr) %} {% set interval_hours =
hours_difference / api_request_limit %} {% set ns = namespace(match =
false) %} {% for i in range(api_request_limit) %}
{% set start_time = nr + (i * interval_hours) %}
{% if ((start_time - timedelta(seconds=30)) <= now()) and (now() <= (start_time + timedelta(seconds=30))) %}
{% set ns.match = true %}
{% endif %}
{% endfor %} {{ ns.match }}
condition:
- condition: sun
before: sunset
after: sunrise
data: {}
mode: single
I am on v4.0.23 as free user with automation that gets the data 10 times in a day. currently it seems working/running good. should I just wait for a new repo and then migrate? or are there any other suggested migration paths already?
i think is best to wait.
Just great! Better using this compared to the limited api endpoint of solcast where you never know when they will shutdown their free service.
I configured it and the given data is very equally to solcast.
Only constraint is that two different arrays (one south one north) are not working. But could surely be requested as this dev is very responsive!
Thanks for sharing!
