had to delete my previous setup as I have two panel directions configured and it was doubling up now that the integration handles that differently. Just entered my API key again and added the forecast back to my energy dashboard and it’s bang on.
Hello. I am trying to have Solcast PV forecast integration running.
I have it istalled 2.2.3 via HACS.
I have an API key already, but I am stuck in the next step - how to configure?
It seems that I am missing something
The only way where it appears is in HACS. I am not able to add integration in Settings as it is not there.
Any advice please?
I have installed the integration via HACS and configured it with the JSON format API, but it doesn’t seem to be pulling in any data. Is there something else I need to enable?
I get a lot of these messages in the log lately. Is there something I should do differently please?
This error originated from a custom integration.
Logger: custom_components.solcast_solar.coordinator
Source: custom_components/solcast_solar/coordinator.py:137
Integration: Solcast PV Forecast (documentation, issues)
First occurred: 09:10:10 (1 occurrences)
Last logged: 09:10:10
update_forecast: Traceback (most recent call last): File "/config/custom_components/solcast_solar/coordinator.py", line 133, in update_forecast for update_callback in self._listeners: RuntimeError: dictionary changed size during iteration
Edit: I checked back through previous release notes and deleted the /config/solcast.json file, restarted HA and kicked off the call to Solcast. Got the same error in slightly different place:
File "/config/custom_components/solcast_solar/coordinator.py", line 149, in service_event_update
Happening hourly. I guess something changed and needs a tweak from the Dev.
I’ve just set up Solcast and installed the integration. I have two sites registered on Solcast, as I have two different orientations for my panels. I only have one API key, and it looks like the integration is combining the two sites ok in that today’s today roughly matches my actual. Is that all I need to do to combine them?
My solar install was commissioned today (after weeks of delays!). I have panels on FOUR roof faces and TWO inverters as I have a two phase power supply (don’t ask). I’ve set up two accounts at SolCast and have set up my two systems (one per account, two roof faces per system). The forecast looks all good (can’t comment on accuracy obviously) but I cannot bring both data sets into HA with the integration. I’ve set it up with my two API keys separate by a comma, and I’ve tried setting up the integration twice each with their own API key. Individually they seem to work…but together I only get 15 entities (it’s 13 for one on its own), and the two ‘diagnostic’ entities that I do get just revert to 0 and refuse to update. I had kind of expected just to get two of everything…but no…
Not sure if I’m missing something or not…I have a funny feeling I’m missing something obvious.
