Solcast Global Solar Power Forecast Integration
I have I done something funny along the way?
My diagnostic sensor.solcast_myname shows up on main Map.
Does this happen for anyone else? My room is outside if that makes any difference.
Edit: It does get removed and replaced when the integration is deleted and installed.
OKā€¦so I posted my message, had a shower, and when I came back it had magically sorted itself out - all the data is there now and everything is nicely added up! So very cool. :slight_smile:
Butā€¦this morning my forecast was goneā€¦and it turns out that I have exhausted all of my API calls alreadyā€¦in one hour it went for 14 remaining to 0ā€¦so how do I limit the calls? One per hour would be ampleā€¦and since there are two account counting independently that should ensure I never run outā€¦
Help?
Yes, I donā€™t use the default map tab for that reason (lots of things that shouldnt show up do). I made a dashboard and use a map card in panel view.
Ahh good to know it wasnā€™t just me.
I didnā€™t recall setting it upā€¦ But i didnā€™t put it past myself as having done it and forgotten where.
Is it just me or has the Solcast forecast disappeared with the latest beta of HA? If I go to configure the Energy dashboard and click on the Forecast Production button next to my panels, it now offers me only the opportunity to manually configure parameters for a Forecast.Solar forecast and Solcast is no longer visible. Iā€™ve removed and re-added the Solcast integration, but no effect.
Mine still shows. I do find that occasionally I have to restart HA to get Solcast to show up after some changes.
Same again with todayā€™s HA update. Energy dashboard no longer recognises the existence of the Solcast integration.
Restarted multiple times. Deleted, re-downloaded, re-added Solcast. Still doesnā€™t show up when trying to add a forecast to panels in the energy dashboard.
So forecast is working better for meā€¦but now I have a couple of questions:
  1. Controlling polling
    It looks like Iā€™m polling when it is dark and the panels have already stopped producingā€¦it doesnā€™t poll in the dead of night (much) but is there a way to set start and end times for polling?
  2. API call consumption
    Per poll it sometimes consumes 4 API callsā€¦and other times it seems to chew through 10ā€¦my poll count from yesterday (per interval) comes back as:
    46, 42, 34, 30, 26, 18, 14, 10, 2, -6
    Meaning the API calls per hour were:
    4, 4, 8, 4, 4, 8, 4, 4, 8, 8
    A restart of HA could account for an extra polling cycle but I didnā€™t restart it that oftenā€¦?
  3. API counts for multiple accounts
    I have two accounts with SolCast as I have two systems, each with two strings facing N/E and N/Wā€¦which means that I have 50 API calls per account or a total of 100 calls. The API count tracker doesnā€™t consider this when ticking off the remaining calls so I get negative API counts remaining once I get past the halfway point (I start at 50, and end on -40ish). This is a minor bug that should be easy to fix by setting the API call starting value equal to the 50 x the number of accounts provided.
Cheers!
I have the same problem
All sensors are showing 0 after updating to 3.0.25. Showing error in log.
Logger: custom_components.solcast_solar.solcastapi
Source: custom_components/solcast_solar/solcastapi.py:127
Integration: Solcast PV Forecast (documentation, issues)
First occurred: 11:20:57 AM (1 occurrences)
Last logged: 11:20:57 AM
Solcast http_data error: Traceback (most recent call last): File "/config/custom_components/solcast_solar/solcastapi.py", line 386, in http_data found_data = [d for d in _data if d['period_end'] == item['period_end']] File "/config/custom_components/solcast_solar/solcastapi.py", line 386, in <listcomp> found_data = [d for d in _data if d['period_end'] == item['period_end']] KeyError: 'period_end'
This is a great integration but I am struggling with a few things:
  • I canā€™t install through HACS. No sign of itā€¦ so I have done a manual install from the GH repo
  • I seem to only have 10 API requests on my account. Itā€™s not clear to me how the upgrade to 50 happensā€¦
  • Iā€™d like to also use the 10% and 90% estimates but Iā€™m not seeing them in HA though it looks like they should be available
Hi @gerasalus - Would it be possible to see your completed code for this Actual vs Forecasted graph? Have been trying to get mine working, but having some issues.
Thanks!
Iā€™ve had issues with zero values a few times since id updated to the 3.0.30 update (was was using 3.0.3 beta prior). Sometimes it clears if you go into the following starting at the main menu on the side:
settings/devices and services
then scroll to the solecist integration.
Click on the three little dots, and then click reload.
Had a funny one yesterday.
@anon7821378 thanks for including the detailed forecasts at 30 minute resolution, I had a separate REST call which I no longer need to use and will reduce my API calls. Thanks.
Upstream (Solcast) seem to provide their 30 minute forecasts in kW - forecast power during the period.
Your integration seems to be providing the 30 minute pv_forecasts in kWh (which is half the kW value as it is only for half an hour) - forecast energy during the period
Both of course are correct, just different ways of measuring.
I just wanted to make sure I understood your integration.
How to create automation, polling forecast data starting 7:00 AM, every 1 hour? Until 10 API calls.
Or, is that not the best way?
I just set this up, and currently using automatic polling with free account.
Thanks oziee for the great integration and further support. The automation script here didnā€™t work for me. Trying a bit further I landed on updating the action as follows:
alias: Solcast_update
description: New API call Solcast
  - platform: time_pattern
    minutes: "0"
    seconds: "0"
condition:
  - condition: sun
    before: sunset
    after: sunrise
  - service: solcast_solar.update_forecasts
    data: {}
mode: single
I created 1 account.
Then I created 2 sites for both our solar panel groups:
Installed Solcast integration and configured with the API key, which I only have 1 API key.
Is this how it is supposed to be? 1 API key for both sites. Or, should I create 2 accounts with 1 site each?
From the entities, I always see ā€œRoof 35ā€ is 0
And the last pulled is Yesterday, which is not true as I use automation to call Solcast forecast update service. You see API used is 5, pulled every hour since sunrise, until sunset.
Anyone has any idea?
@del13r how about your Solcast setup?
18 of my 22 panels face north (81%).
The other 2 pairs face east and west.
I only have 1 rooftop site setup in solcast and that does the job.
Here is my solcast settings
Here is my layout and output on a sunny day on the 4th of Feb.
Dotted line is what solcast predicted.
