Solcast Integration - Forecasted data not being graphed on apex charts
The problem
I’m not getting any graph lines for the forecasted data when using apex charts to show the solcast integration data.
There’s data for the integration - but i cant get it to display, most likely me nuffing up syntax somewhere.
Troubleshooting so far:
  • There’s data from the solcast integration
  • I’m seeing updates for the sensors that i’m using “sensor.solcast_pv_forecast_forecast_today”
  • The sensors are showing the totals in the graph on the dashboard, just not the lines
  • i’ve reloaded the solcast integration
  • i’ve reloaded HA
    still no joy…
Here’s what it looks like:
Chart
Looking at the sensor “sensor.solcast_pv_forecast_forecast_today” in HA integrations:
Attributes:
DetailedForecast
  • period_start: ‘2023-09-18T00:00:00+10:00’
    pv_estimate: 0
    pv_estimate10: 0
    pv_estimate90: 0
  • period_start: ‘2023-09-18T00:30:00+10:00’
    pv_estimate: 0
    pv_estimate10: 0
    pv_estimate90: 0
Here’s the code to generate the graph:
data_generator: |
return entity.attributes.detailedforecast.map((entry) => {
return [new Date(entry.period_start), entry.pv_estimate];
Full Code:
type: custom:apexcharts-card
apex_config:
chart:
height: 350px
all_series_config:
unit: ' kWh'
header:
title: Solar forecast
show: true
standard_format: true
show_states: true
colorize_states: true
graph_span: 2d
span:
start: day
offset: '-0h'
now:
show: true
label: Now
yaxis:
* id: kwh
min: 0
apex_config:
tickAmount: 5
* id: header_only
show: false
series:
* entity: sensor.solcast_pv_forecast_forecast_today
yaxis_id: kwh
type: area
color: orange
data_generator: |
show:
legend_value: false
in_header: false
stroke_width: 3
float_precision: 2
extend_to: false
* entity: sensor.solcast_pv_forecast_forecast_tomorrow
yaxis_id: kwh
type: area
color: orange
data_generator: |
show:
legend_value: false
in_header: false
stroke_width: 3
float_precision: 2
extend_to: false
yaxis_id: header_only
color: orange
show:
legend_value: true
in_header: true
in_chart: false
* entity: sensor.solcast_pv_forecast_forecast_remaining_today
color: orange
show:
legend_value: true
in_header: true
in_chart: false
color: grey
show:
legend_value: true
in_header: true
in_chart: false
Any luck on this?
I have exactly the same issue as @natbesh. Solcast is working both at site and in HA instance. I have solcast data from entities graphed via predbat but when trying to create this apex card (same code by looks) just hangs with loading message.
Solved it. The APEX chart was calling “Forecast” rather than “detailedForecast” in the data fetch.
Revised Code:
apex_config:
  chart:
    height: 350px
all_series_config:
  unit: ' kWh'
header:
  show: true
  show_states: true
graph_span: 2d
span:
  start: day
  offset: '-0h'
now:
  show: true
  label: Now
yaxis:
  - id: kwh
    min: 0
    apex_config:
      tickAmount: 5
  - id: header_only
    show: false
series:
  - entity: sensor.solcast_pv_forecast_forecast_today
    yaxis_id: kwh
    type: area
    color: orange
    data_generator: |
      var today = entity.attributes.detailedForecast.map((start, index) => {
        return [new Date(start["period_start"]).getTime(), entity.attributes.detailedForecast[index]["pv_estimate"]];
      var data = today
      return data;
    show:
      legend_value: false
      in_header: false
    stroke_width: 3
    float_precision: 2
    extend_to: false
  - entity: sensor.solcast_pv_forecast_forecast_tomorrow
    yaxis_id: kwh
    type: area
    color: grey
    data_generator: |
      var data = today
      return data;
    show:
      legend_value: false
      in_header: false
    stroke_width: 3
    float_precision: 2
    extend_to: false
    color: orange
    show:
      legend_value: true
      in_header: true
      in_chart: false
  - entity: sensor.solcast_pv_forecast_forecast_remaining_today
    color: orange
    show:
      legend_value: true
      in_header: true
      in_chart: false
    color: grey
    show:
      legend_value: true
      in_header: true
      in_chart: false
  - entity: sensor.solcast_pv_forecast_api_last_polled
    unit: ' min.'
    transform: return ((Date.now()) - (new Date(x).getTime())) / 60 / 60 / 24
    show:
      legend_value: true
      in_header: true
      in_chart: false
This has been baffling me for days. thanks for the fix!!!
It looks to me as if the graphs should be in kW not kWh, or I am misunderstanding. Otherwise many thanks for this excellent example. Just what I needed to get going with Solcast.
