Hi
Received my HA Yellow with CM4 + SSD
Connected to network + Plugged in - Constant Red + Green LED’s
Assumed device software is not on board as expected so connected to PC & reloaded via USB-C then reinstalled firmware using USB drive which progressed all the way to solid Red LED indicating success.
Ethernet cable plugged in - insert power cable (Non POE unit) - Solid RED + Green LED’s!?
Tested Ethernet cable - can access internet using cable with Wifi disabled.
Any Ideas?
