For Solis inverters with datalogger, data is uploaded to the Soliscloud. Would be nice to be able to add this data to Home-assistant.
Someone willing to pick this up as an integration or template?
(In the forum there are some discussions about interface scraping and using the RS485 port with an ESP device, for local and cloud independent connectivity nice; cloud-service could be more useful).
An API is available; see links below
How to get acces
API documentation
mattjmet
(Mattjmet)
April 30, 2023, 12:04am
2
First off thanks for the heads up about the API! It’s been annoying me for ages that I could t get the data from my inverter.
A full integration is beyond my capabilities, but I have started poking into getting a single request working.
Due to the auth method, it’s quite finicky, but I think I have it working.
When there’s something wrong with the auth I get a specific error.
That said I’m continually getting time out responses and gave up after having raised a ticket with Solis
Have you had any luck getting data back from the API?
Had some tries to get a bootstrap call going using PostMan → no luck (lack of skills on my side, auth looked complicated to get it going) > hope to spend some time soon to do a bit more of a deep dive.
mattjmet
(Mattjmet)
May 20, 2023, 1:30pm
4
I found this integration on github that has been working well for me it added the option to support the new API some time ago.
Thanks for sharing, will try it out.
Found a Python implementation as well; posting here for future reference GitHub - hultenvp/soliscloud_api: Python implementation for the SolisCloud API
Hi there, do you know if this is also showing the battery data?
And can it also be incorporated (both solar and battery) in the energy dashboard by using this?
mattjmet
(Mattjmet)
June 19, 2024, 8:18am
8
It does show battery data (SOC, power in/out) but I don’t know about adding any of it to the energy dashboard as I haven’t done that.
Been able to set this up from inverter.cgi as follows;
- platform: rest
name: Inverter Energy Generation
resource: http://datalogger-IP/inverter.cgi
method: GET
username: admin
password: (your wifi password)
value_template: '{{ value.split(";")[4] }}'
scan_interval: 300 # datalogger updates every 5 minutes by default
device_class: power
state_class: measurement
unit_of_measurement: 'W'
- platform: integration
source: sensor.inverter_energy_generation
unit_prefix: k
round: 2
the cgi file contains Inverter_SN;firmware_version;inverter_model;panel_temp;current_solar_generation;total generation;d;alarm_status;
Hello all,
I have integrated my inverter with Home Assistant and I have full access, same information as in the Soliscloud.
I needed to add hacks Addon for Home Assistant and then Solis Inverter integration.
This is the repo of the integration .
To piggyback on this (and then I’ll stop spamming the fora): I forked hultenvp’s repo from above and added some functionality on how to pull some data from a local datalogger with higher update frequency: GitHub - jverplancke/soliscloud_api: Python implementation for the SolisCloud API
