Solmate (EET) integration
it would be cool if Solmate (photovoltaic batterie system from EET (SolMate - EET) could be integrated into Home Assistent.
API on github: GitHub - eet-energy/solmate-sdk: All you need to integrate your EET SolMate into your home automation system
Br, Michael
Hello everyone,
I am also interested in the integration of the Solmate photovoltaic battery system (EET).
I have solar panels and HA installed on a PI4 with the MQTT broker.
I saw that there is a working HA integration with an API on GitHub: GitHub - mmattel/EET-Solmate: Integrate EET SolMate with Homeassistant using MQTT (read AND write!)
Has anyone tried it yet?
Pierre ANDRÉ
I installed it this weekend and it works really fine.
The only problem: It works only with internet connection. Theoretically it should work without as well, but it doesn´t. Maybe I do something wrong, I wrote the developer already, will see…
Br, Michael
I started using it two days ago and it is stable. I installed it via AppDeamon.
As for now, I can endorse mmattel/EET-Solmate: Integrate EET SolMate with Homeassistant using MQTT (read AND write!)
do you use the Addon AppDaemon? Because that´s depricated :frowning:
i am also interreseted on set integration.
is there also video tutorial for this?
