Yesterday I missed a notification even though the companion app was connected.
This has happened before as well but there seems to be no consistency, most of the times it works though.
This is on a tablet with the minimal app on WiFi and now running latest version since before yesterday.
Is there a way to check if a mobile device is connected?
Is there something I can check which might cause this?
How to intercept this ‘not arriving notification’?
Hi Hellis81, thank you for this tip!
I wasn’t aware of this option and have added it now.
I have re-read the docs, did some searches here on the forum but it’s not clear to me were I can find a result if this notification has arrived or not.
I had already seen that part of the companion docs but still I cannot make anything about it because it’s not clear to me where to look for that result.
By sending a notification with the mobile device on and offline, I didn’t find an event in the logs or the logbook.
This will only work on Android devices, you need to go to the Developer Tools and listen to the event " mobile_app_notification_received" after sending the notification.
You can receive an event when a notification is received on the device. In order to receive this event you will need to set confirmation: true as a parameter in your notification service call.All notification data will be present in the event data for the event typemobile_app_notification_received.
Hi randomsnack, I did already set that ‘confirmation: true’ option and now with your explanation I have found it!
Is it possible to use this as a check from the script or automation to get feedback without having to dig it up yourself?
It’s possible to receive an event if you set that ‘confirmation: true’ parameter: that part I understand.
I had never used an event as a trigger so didn’t know this was possible but now that Hellis81 pointed this out, I still cannot figure out how to get some kind of automatic solving/notification/… when the companion app is not connected and therefor a notification doesn’t arrive.
So if the notification has not been received, the automation/script halts and the boolean is not turned on.
I don’t get it how to use this so can you please elaborate a little?
If HA doesn’t get the received event, you can retry the notification, implement exponential back off, or notify a different device that notifications are failing. What ever you want to do if the notification fails.
As Larrikin says the boolean is still off for: 30 seconds then the notification has not arrived at the phone.
There probably needs to be a small delay between sending the notification and the wait for trigger.
My goal was to use another device (media player) if the companion app is not receiving the notification.
What puzzles me: if the automation/script halts, how to continue? (sorry, I don’t see it)
