I assume you you are on windows and have an environment set up on vscode, wsl2 and docker desktop.
The new core version core-2023.6.1 shows a message that asks for python 3.11.
Solution :
Install portainer in your docker.
open the home assistant container
launch the console.
You can now install python 11 with
sudo apt update
sudo apt install software-properties-common wget
wget https://www.python.org/ftp/python/3.11.4/Python-3.11.4.tar.xz
sudo tar -xf Python-3.11.4.tar.xz
cd Python-3.11.4
sudo ./configure --enable-optimizations
sudo make altinstall
be patient…
python 3.1 is installed without the necessary pip dependencies.
I downloaded them from a working home assistant and created an int requirement.txt file which I stored here
Download it in your container (I did it by ftp with wget)
then type
pip install --upgrade pip
install pip -r requirement.txt
be patient again. (you can stop after the message)
INFO: This is taking longer than usual. You might need to provide the dependency resolver with stricter constraints to reduce runtime. See https://pip.pypa.io/warnings/backtracking
restart Vscode and type select python interpreter in the command palette and chose python 3.11
