Thanks for the help
Maybe will somebody else help me with this problem
Good news, I manage to clean the text for the time
And here is the new code:
- platform: rest
json_attributes:
# - timer
- alarm
resource: http://192.168.1.50:8008/setup/assistant/alarms
value_template: '{% if value_json.alarm[0] is defined %}{{ value_json.alarm[0].id }}{% endif %}'
force_update: true
sensors:
# timer1_remaining:
# value_template: '{% if states.sensor.googlehomealarms.attributes.timer[0] is defined %}{{ ((states.sensor.googlehomealarms.attributes.timer[0].fire_time + states.sensor.googlehomealarms.attributes.timer[0].original_duration) / 1000) - as_timestamp(now()) | int }}{% endif %}'
# unit_of_measurement: s
# entity_id: sensor.googlehomealarms
# timer1_end_time:
# value_template: '{% if states.sensor.googlehomealarms.attributes.timer[0] is defined %}{{ ((states.sensor.googlehomealarms.attributes.timer[0].fire_time + states.sensor.googlehomealarms.attributes.timer[0].original_duration) / 1000) | int }}{% endif %}'
alarm1_time:
value_template: "{% if states.sensor.googlehomealarms.attributes.alarm[0] is defined %}{{ states.sensor.googlehomealarms.attributes.alarm[0].time_pattern | regex_replace('..hour..|,|.minute.|..second.....') }}{% endif %}"
alarm1_remaining:
value_template: "{% if states.sensor.googlehomealarms.attributes.alarm[0] is defined %}{{ (((states.sensor.googlehomealarms.attributes.alarm[0].fire_time / 1000) - as_timestamp(now())) /60) | round(0)}}{% endif %}"
unit_of_measurement: "min"
For the changing the names you can do it in lovelace
I hope that this is helping someone
I wish we can see addon at some point! Really want to!!
They added alarms and timers to the google home component already in 0.88:
Thanks! I will try to work with it!!
I need some help with an automation using the use of the official Google Home component. I would like the automation to trigger if the alarm clock time equals my local time.
My current automation looks like this:
- alias: "Tageszeit Morgen"
value_template: '{{ states.sensor.schlafzimmer_alarm.state == utcnow().strftime("%Y-%m-%dT%H:%M:%S+00:00") }}'
- service: input_select.select_option
entity_id: input_select.tageszeit
option: 'Morgen'
For some reason the automation does not trigger, can someone help me please
Thanks in advance!
Hey Malte,
Iāve been trying to do the same thing for weeks and finally figured out. Maybe this helps:
Using theGoogle Home component I tracked the alarms
googlehome:
devices:
- host: IP_ADDRESS
track_alarms: true
Then I added a sensor to convert the time to hours and minutes, as well as a time sensor and a sensor to compare the current time to the alarm time (kudos goes to @nicolaas from and HIS POST) but I tweaked it a little:
sensors:
googlehomealarm:
value_template: "{{ as_timestamp(states('sensor.GOOGLEHOMENAME_alarm')) | timestamp_custom('%H:%M') }}"
- platform: time_date
display_options:
- 'time'
sensors:
google_home_alarm_sensor:
value_template: '{{ states("sensor.time") == states("sensor.googlehomealarm") }}'
And then lastly the automation from @nicolaas
- alias: 'Google Home Wakeup'
- platform: state
entity_id: sensor.google_home_alarm_sensor
service: scene.turn_on
data_template:
entity_id: scene.wakeup
Hope this helps
thanks! it works
Thanks a lot, tried it and it works. But Iād still be interested in why my setup didnāt work beforehandā¦
Ive ran into a wierd situation. Today (sunday) my automation was triggered for my alarm set on 8 am monday. I assume becuase the sensor will just read 8:00 and it triggered at 8:00 am regardless of the day. how can we make it have to match the day and time to trigger? same game with sensor.date?
edit: heres whats i came up with but it wasnt triggering. just gotta add the ādate_timeā sensor sand then match it
basementalarm:
value_template: "{{ as_timestamp(states('sensor.basement_speaker_alarm')) | timestamp_custom('%Y-%m-%d,%H:%M') }}"
basement_alarm_sensor:
value_template: '{{ states("sensor.date_time") == states("sensor.basementalarm") }}'
edit this works great.
Thanks for the code!
@donbirko thanks for the code. It worked!
my googlehome alarm broken this week. Any pointers from the errors
2019-06-14 10:32:56 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform googlehome
File ā/usr/src/homeassistant/homeassistant/components/googlehome/sensor.pyā, line 38, in async_setup_platform
seems indeed not to work anymore
take a look here:
https://community.home-assistant.io/t/google-home-alarm-track-error/124046/2?u=gekomax
Just wondering if this solution still works or not anymore?
If not are there any workaround to let Home assistant know alarm time via voice and google home?
Any update on this?
Google has closed off this method of accessing the google home devices.
Hey, it is actually possible to gain access to the Google Home local API again, but itās a bit more hassle since it requires authentication by short-lived tokens now. Rithvik Vibhu has done some excellent work figuring out how to do this.
To integrate this back into Hass (I was using e.g. the alarms API for my wakeup light routine), I wrote a very simple bash script that can automatically retrieve these tokens and push them to Home Assistant as an entity attribute, which can subsequently be used in templating. My script is available here:
Hope itās helpful to someone!
Iām looking the requirements to run your script. Where do I put the Google Foyer proto files? Iām running a raspberry pi 4
