Solution to track your google home alarms and timers and trigger different home assistant events
Hi all,
can sombody help me on this ?
where and how to create the entity for the sensor.xxxxx_timers, is it in HA or in my Google home app on my phone.
i am new to HA and no programmer, thanks in advance.
I am/was so excited to use this new integration , i immediately tried.
I added an app password and succesfully logged in.
However i dont see any entities
But lots of messages in log
  • Config entry for xx google home integration not ready yet
  • waiting on integrations to complete setup google home
  • failed to acces xxx , api returned 401 client respons xxx [401 Unauthorized]> <CIMultiDictProxy(ā€˜Access-Control-Allow-Headersā€™: ā€˜Content-Typeā€™, ā€˜Cache-Controlā€™: ā€˜no-cacheā€™, ā€˜Content-Lengthā€™: ā€˜0ā€™)>
  • Unexpected error fetching sensor data: 4 is not a valid GoogleHomeAlarmStatus
any help pls?
i dont get any email to confirm app password
Upgraded to latest version and now sensors are coming visible :slight_smile:
Thank you so much for this custom integration!
It inspired me to create a Node-RED flow so all the alarms and timers are send as notifications to my phone.
I wanted to share this so I wrote my first blog post about it:
Get Google Home alarms & timers as notifications
upgraded but I dā€™ont get any entitees
Can you help on this.
where and how do i Create the sensorsā€¦
They are auto created in home assistant.
Not in google home.
Did you add the integration in HA?
Go to the integration then and there you have the entities
Yes I did
but no Entitiesā€¦
Log Shows:
``yaml
2021-04-13 19:05:10 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 400
The error is from another integration: google_assistant and has nothing to do with the Google Home integration.
Have a look at https://github.com/leikoilja/ha-google-home#troubleshooting to enable debug logs for this integration and search for the correct log lines.
Also have you tried restarting the host system, not only HA. That worked for me (in an unrelated issue).
Restarting the hostā€¦no change.
Underneath the log ,looks like he is trying to setup a timer but could not determine the IP address.
i am using a firewall is there a surtain port that need to be open ?
2021-04-13 21:49:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-13 21:49:58 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'my', 'myhome', 'automation', 'input_datetime', 'input_select', 'persistent_notification', 'climate', 'google_home', 'sun', 'zeroconf', 'device_tracker', 'tts', 'switch', 'script', 'timer', 'esxi_stats', 'default_config', 'counter', 'cover', 'blueprint', 'input_boolean', 'met', 'scene', 'tag', 'sensor', 'ssdp', 'input_text', 'system_health', 'light', 'input_number', 'updater', 'media_source', 'history', 'group', 'hacs', 'mobile_app', 'trace', 'logbook', 'dhcp', 'zone', 'google_assistant', 'map'}
2021-04-13 21:49:58 DEBUG (MainThread) [homeassistant.setup] Dependency google_home will wait for after dependencies ['zeroconf']
2021-04-13 21:50:00 INFO (MainThread) [homeassistant.setup] Setting up google_home
2021-04-13 21:50:00 INFO (MainThread) [homeassistant.setup] Setup of domain google_home took 0.0 seconds
2021-04-13 21:50:00 INFO (MainThread) [custom_components.google_home]
2021-04-13 21:50:00 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en: nexia, monoprice, alarmdecoder, zwave_js, hvv_departures, bsblan, canary, econet, hangouts, songpal, tuya, profiler, life360, lutron_caseta, geonetnz_quakes, hue, abode, gree, rituals_perfume_genie, pi_hole, rachio, cast, konnected, axis, zwave, nzbget, hacs, brother, toon, lifx, meteo_france, home_connect, traccar, cert_expiry, xiaomi_miio, arcam_fmj, wemo, acmeda, smarthab, azure_devops, kodi, blink, tesla, nightscout, cloudflare, adguard, sonarr, mill, shelly, rpi_power, accuweather, tradfri, geofency, myq, gpslogger, opentherm_gw, ecobee, rainmachine, hunterdouglas_powerview, ondilo_ico, tado, homekit, yeelight, twentemilieu, dialogflow, apple_tv, mikrotik, gdacs, almond, poolsense, gios, openweathermap, pvpc_hourly_pricing, tibber, smarttub, ipma, upcloud, verisure, wiffi, vizio, twinkly, vera, kmtronic, unifi, wolflink, elkm1, eafm, wled, xiaomi_aqara, ifttt, spider, syncthru, hive, fritzbox_callmonitor, neato, deconz, mysensors, totalconnect, vesync, somfy, enocean, risco, bmw_connected_drive, dunehd, mailgun, sense, goalzero, tile, airvisual, epson, vilfo, dexcom, hyperion, fritzbox, ring, huisbaasje, philips_js, nws, ruckus_unleashed, icloud, flo, smappee, huawei_lte, recollect_waste, esphome, progettihwsw, plex, control4, ozw, flunearyou, met, devolo_home_control, melcloud, glances, mazda, locative, nest, soma, fireservicerota, nuheat, spotify, homematicip_cloud, motion_blinds, local_ip, dynalite, logi_circle, sharkiq, simplisafe, starline, upnp, wilight, point, smhi, nuki, isy994, notion, august, smart_meter_texas, atag, insteon, twilio, bond, kulersky, airly, habitica, iqvia, directv, lyric, xbox, zha, flume, samsungtv, somfy_mylink, ambient_station, tasmota, nut, shopping_list, advantage_air, heos, homekit_controller, roku, roon, aemet, ps4, flick_electric, roomba, ambiclimate, google_home, denonavr, srp_energy, rfxtrx, mullvad, asuswrt, coolmaster, forked_daapd, garmin_connect, powerwall,  ...
2021-04-13 21:50:00 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 34, "type": "result", "success": true, "result": {"resources": {"component.juicenet.title": "JuiceNet", "component.onewire.title": "1-Wire", "component.wiffi.title": "Wiffi", "component.ovo_energy.title": "OVO Energy", "component.izone.title": "iZone", "component.plugwise.title": "Plugwise", "component.tellduslive.title": "Telldus Live", "component.litejet.title": "LiteJet", "component.blebox.title": "BleBox devices", "component.squeezebox.title": "Logitech Squeezebox", "component.broadlink.title": "Broadlink", "component.agent_dvr.title": "Agent DVR", "component.sms.title": "SMS notifications via GSM-modem", "component.aurora.title": "NOAA Aurora Sensor", "component.faa_delays.title": "FAA Delays", "component.doorbird.title": "DoorBird", "component.smartthings.title": "SmartThings", "component.speedtestdotnet.title": "Speedtest.net", "component.withings.title": "Withings", "component.mqtt.title": "MQTT", "component.harmony.title": "Logitech Harmony Hub", "component.braviatv.title": "Sony Bravia TV", "component.hlk_sw16.title": "Hi-Link HLK-SW16", "component.subaru.title": "Subaru", "component.keenetic_ndms2.title": "Keenetic NDMS2 Router", "component.onvif.title": "ONVIF", "component.ios.title": "Home Assistant iOS", "component.islamic_prayer_times.title": "Islamic Prayer Times", "component.gogogate2.title": "Gogogate2 and iSmartGate", "component.esxi_stats.title": "ESXi Stats", "component.owntracks.title": "OwnTracks", "component.awair.title": "Awair", "component.upb.title": "Universal Powerline Bus (UPB)", "component.sonos.title": "Sonos", "component.iaqualink.title": "Jandy iAqualink", "component.metoffice.title": "Met Office", "component.solarlog.title": "Solar-Log", "component.myhome.title": "MyHome", "component.zerproc.title": "Zerproc", "component.ipp.title": "Internet Printing Protocol (IPP)", "component.transmission.title": "Transmission", "component.solared ...
2021-04-13 21:50:08 DEBUG (MainThread) [custom_components.hacs] <Plugin DurgNomis-drol/google_home_timers_card> Getting repository information
2021-04-13 21:50:08 DEBUG (MainThread) [custom_components.hacs] <Plugin DurgNomis-drol/google_home_timers_card> Running checks against v0.2.0
2021-04-13 21:50:21 DEBUG (MainThread) [custom_components.google_home] Failed to fetch timers/alarms information from device Woonkamer-TV. We could not determine it's IP address, the device is either offline or is not compatible Google Home device. Will try again later.
2021-04-13 21:50:21 DEBUG (MainThread) [custom_components.google_home] Failed to fetch timers/alarms information from device Grote slaapkamer. We could not determine it's IP address, the device is either offline or is not compatible Google Home device. Will try again later.
2021-04-13 21:50:21 DEBUG (MainThread) [custom_components.google_home] Finished fetching sensor data in 21.633 seconds
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=google_home>
2021-04-13 21:50:21 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.google_home
2021-04-13 21:50:21 INFO (MainThread) [homeassistant.components.switch] Setting up switch.google_home
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 3, "type": "event", "event": {"event_type": "component_loaded", "data": {"component": "google_home"}, "origin": "LOCAL", "time_fired": "2021-04-13T19:50:21.687057+00:00", "context": {"id": "6093143768696029b8a9efcdc5a36b91", "parent_id": null, "user_id": null}}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 9, "type": "event", "event": {"event_type": "component_loaded", "data": {"component": "google_home"}, "origin": "LOCAL", "time_fired": "2021-04-13T19:50:21.687057+00:00", "context": {"id": "6093143768696029b8a9efcdc5a36b91", "parent_id": null, "user_id": null}}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=google_home, service=delete_alarm>
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=google_home, service=delete_timer>
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=google_home, service=reboot_device>
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 5, "type": "event", "event": {"event_type": "service_registered", "data": {"domain": "google_home", "service": "delete_alarm"}, "origin": "LOCAL", "time_fired": "2021-04-13T19:50:21.689579+00:00", "context": {"id": "3d602b414dcafa3be874467753da2fc9", "parent_id": null, "user_id": null}}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 5, "type": "event", "event": {"event_type": "service_registered", "data": {"domain": "google_home", "service": "delete_timer"}, "origin": "LOCAL", "time_fired": "2021-04-13T19:50:21.689774+00:00", "context": {"id": "f11cf83c8f814780bf9a6752655482c1", "parent_id": null, "user_id": null}}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 5, "type": "event", "event": {"event_type": "service_registered", "data": {"domain": "google_home", "service": "reboot_device"}, "origin": "LOCAL", "time_fired": "2021-04-13T19:50:21.689914+00:00", "context": {"id": "7ea17774a4e111676b1fa051a05d1b0c", "parent_id": null, "user_id": null}}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 59, "type": "result", "success": true, "result": {"latitude": 51.15553274499742, "longitude": 4.34562385082245, "elevation": 0, "unit_system": {"length": "km", "mass": "g", "pressure": "Pa", "temperature": "\u00b0C", "volume": "L"}, "location_name": "Begoniaweg", "time_zone": "Europe/Brussels", "components": ["device_tracker", "counter", "device_automation", "tts.google_translate", "blueprint", "met", "lovelace", "ssdp", "input_number", "sensor.time_date", "sensor.mobile_app", "switch.google_home", "history", "image", "hacs", "trace", "logbook", "climate.myhome", "binary_sensor.updater", "sensor.template", "input_boolean", "onboarding", "automation", "input_datetime", "input_select", "zeroconf", "climate", "switch", "script", "cloud", "system_log", "person", "default_config", "config", "http", "binary_sensor.myhome", "tag", "auth", "logger", "media_source", "api", "notify.mobile_app", "mobile_app", "alexa", "device_tracker.mobile_app", "my", "persistent_notification", "binary_sensor", "sun", "google_home", "template", "homeassistant", "binary_sensor.mobile_app", "sensor.esxi_stats", "sensor.myhome", "hassio", "sensor.hassio", "system_health", "search", "light", "updater", "sensor.hacs", "webhook", "sensor.google_home", "dhcp", "google_assistant", "myhome", "scene.homeassistant", "frontend", "cover.myhome", "tts", "timer", "sensor.systemmonitor", "esxi_stats", "stream", "cover", "light.myhome", "scene", "sensor", "input_text", "weather.met", "websocket_api", "switch.myhome", "recorder", "binary_sensor.hassio", "group", "weather", "notify", "zone", "map", "analytics"], "config_dir": "/config", "whitelist_external_dirs": ["/config/www", "/media"], "allowlist_external_dirs": ["/config/www", "/media"], "allowlist_external_urls": [], "version": "2021.4.4", "config_source": "yaml", "safe_mode": false, "state": "STARTING", "external_url": null, "internal_url": null}}
2021-04-13 21:50:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 60, "type": "result", "success": true, "result": {"latitude": 51.15553274499742, "longitude": 4.34562385082245, "elevation": 0, "unit_system": {"length": "km", "mass": "g", "pressure": "Pa", "temperature": "\u00b0C", "volume": "L"}, "location_name": "Begoniaweg", "time_zone": "Europe/Brussels", "components": ["device_tracker", "counter", "device_automation", "tts.google_translate", "blueprint", "met", "lovelace", "ssdp", "input_number", "sensor.time_date", "sensor.mobile_app", "switch.google_home", "history", "image", "hacs", "trace", "logbook", "climate.myhome", "binary_sensor.updater", "sensor.template", "input_boolean", "onboarding", "automation", "input_datetime", "input_select", "zeroconf", "climate", "switch", "script", "cloud", "system_log", "person", "default_config", "config", "http", "binary_sensor.myhome", "tag", "auth", "logger", "media_source", "api", "notify.mobile_app", "mobile_app", "alexa", "device_tracker.mobile_app", "my", "persistent_notification", "binary_sensor", "sun", "google_home", "template", "homeassistant", "binary_sensor.mobile_app", "sensor.esxi_stats", "sensor.myhome", "hassio", "sensor.hassio", "system_health", "search", "light", "updater", "sensor.hacs", "webhook", "sensor.google_home", "dhcp", "google_assistant", "myhome", "scene.homeassistant", "frontend", "cover.myhome", "tts", "timer", "sensor.systemmonitor", "esxi_stats", "stream", "cover", "light.myhome", "scene", "sensor", "input_text", "weather.met", "websocket_api", "switch.myhome", "recorder", "binary_sensor.hassio", "group", "weather", "notify", "zone", "map", "analytics"], "config_dir": "/config", "whitelist_external_dirs": ["/config/www", "/media"], "allowlist_external_dirs": ["/config/www", "/media"], "allowlist_external_urls": [], "version": "2021.4.4", "config_source": "yaml", "safe_mode": false, "state": "RUNNING", "external_url": null, "internal_url": null}}
2021-04-13 21:50:22 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en: sensor.google_home, switch.google_home
2021-04-13 21:50:22 DEBUG (SyncWorker_3) [homeassistant.util.json] JSON file not found: /config/custom_components/google_home/translations/sensor.en.json
2021-04-13 21:50:22 DEBUG (SyncWorker_3) [homeassistant.util.json] JSON file not found: /config/custom_components/google_home/translations/switch.en.json
2021-04-13 21:50:22 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613399538368] Sending {"id": 63, "type": "result", "success": true, "result": {"resources": {"component.onboarding.title": "Home Assistant Onboarding", "component.analytics.title": "Analytics", "component.map.title": "Map", "component.input_boolean.title": "Input boolean", "component.zone.title": "Zone", "component.notify.title": "Notifications", "component.alexa.title": "Amazon Alexa", "component.dhcp.title": "DHCP Discovery", "component.weather.title": "Weather", "component.mobile_app.title": "Mobile App", "component.logbook.title": "Logbook", "component.trace.title": "Trace", "component.hacs.title": "HACS", "component.image.title": "Image", "component.group.title": "Group", "component.api.title": "Home Assistant API", "component.webhook.title": "Webhook", "component.history.title": "History", "component.media_source.title": "Media Source", "component.recorder.title": "Recorder", "component.updater.title": "Updater", "component.logger.title": "Logger", "component.input_number.title": "Input number", "component.light.title": "Light", "component.search.title": "Search", "component.system_health.title": "System Health", "component.hassio.title": "Home Assistant Supervisor", "component.auth.title": "Auth", "component.websocket_api.title": "Home Assistant WebSocket API", "component.input_text.title": "Input text", "component.sensor.title": "Sensor", "component.ssdp.title": "Simple Service Discovery Protocol (SSDP)", "component.tag.title": "Tag", "component.lovelace.title": "Lovelace", "component.scene.title": "Scene", "component.met.title": "Meteorologisk institutt (Met.no)", "component.http.title": "HTTP", "component.blueprint.title": "Blueprint", "component.cover.title": "Cover", "component.device_automation.title": "Device Automation", "component.google_assistant.title": "Google Assistant", "component.counter.title": "Counter", "component.config.title": "Configuration", "component.default_config. ...
2021-04-13 21:50:22 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613213434928] Sending {"id": 9, "type": "result", "success": true, "result": {"latitude": 51.15553274499742, "longitude": 4.34562385082245, "elevation": 0, "unit_system": {"length": "km", "mass": "g", "pressure": "Pa", "temperature": "\u00b0C", "volume": "L"}, "location_name": "Begoniaweg", "time_zone": "Europe/Brussels", "components": ["device_tracker", "counter", "device_automation", "tts.google_translate", "blueprint", "met", "lovelace", "ssdp", "input_number", "sensor.time_date", "sensor.mobile_app", "switch.google_home", "history", "image", "hacs", "trace", "logbook", "climate.myhome", "binary_sensor.updater", "sensor.template", "input_boolean", "onboarding", "automation", "input_datetime", "input_select", "zeroconf", "climate", "switch", "script", "cloud", "system_log", "person", "default_config", "config", "http", "binary_sensor.myhome", "tag", "auth", "logger", "media_source", "api", "notify.mobile_app", "mobile_app", "alexa", "device_tracker.mobile_app", "my", "persistent_notification", "binary_sensor", "sun", "google_home", "template", "homeassistant", "binary_sensor.mobile_app", "sensor.esxi_stats", "sensor.myhome", "hassio", "sensor.hassio", "system_health", "search", "light", "updater", "sensor.hacs", "webhook", "sensor.google_home", "dhcp", "google_assistant", "myhome", "scene.homeassistant", "frontend", "cover.myhome", "tts", "timer", "sensor.systemmonitor", "esxi_stats", "stream", "cover", "light.myhome", "scene", "sensor", "input_text", "weather.met", "websocket_api", "switch.myhome", "recorder", "binary_sensor.hassio", "group", "weather", "notify", "zone", "map", "analytics"], "config_dir": "/config", "whitelist_external_dirs": ["/config/www", "/media"], "allowlist_external_dirs": ["/config/www", "/media"], "allowlist_external_urls": [], "version": "2021.4.4", "config_source": "yaml", "safe_mode": false, "state": "RUNNING", "external_url": null, "internal_url": null}}
2021-04-13 21:50:22 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140613213434928] Sending {"id": 11, "type": "result", "success": true, "result": {"persistent_notification": {"create": {"name": "", "description": "Show a notification in the frontend.", "fields": {"message": {"description": "Message body of the notification. [Templates accepted]", "example": "Please check your configuration.yaml."}, "title": {"description": "Optional title for your notification. [Optional, Templates accepted]", "example": "Test notification"}, "notification_id": {"description": "Target ID of the notification, will replace a notification with the same ID. [Optional]", "example": 1234}}}, "dismiss": {"name": "", "description": "Remove a notification from the frontend.", "fields": {"notification_id": {"description": "Target ID of the notification, which should be removed. [Required]", "example": 1234}}}, "mark_read": {"name": "", "description": "Mark a notification read.", "fields": {"notification_id": {"description": "Target ID of the notification, which should be mark read. [Required]", "example": 1234}}}}, "homeassistant": {"turn_off": {"name": "Generic turn off", "description": "Generic service to turn devices off under any domain.", "fields": {}, "target": {"entity": {}}}, "turn_on": {"name": "Generic turn on", "description": "Generic service to turn devices on under any domain.", "fields": {}, "target": {"entity": {}}}, "toggle": {"name": "Generic toggle", "description": "Generic service to toggle devices on/off under any domain", "fields": {}, "target": {"entity": {}}}, "stop": {"name": "Stop", "description": "Stop the Home Assistant service.", "fields": {}}, "restart": {"name": "Restart", "description": "Restart the Home Assistant service.", "fields": {}}, "check_config": {"name": "Check configuration", "description": "Check the Home Assistant configuration files for errors. Errors will be displayed in the Home Assistant log.", "fields": {}}, "update_entity": {"name": "Update ...
Not sure if its relevant but are you also using mdns and home assistant cloud?
Anyone have an example of an automation based on google home alarm?
If its set?
For exapmple of one google home has an alarm, then light up a lightā€¦
What device is ā€˜Grote slaapkamerā€™? Tvā€™s are incompatible and wonā€™t create a sensor in my experience.
That might be a google home device thats in his big bedroom (grote slaapkamer)
Correct a Google Nest
You did use the same google account did you?
Ok get it to work, teh problem was the Vlan network.
many thanks for the help.
Nice
Unifi network?
What are you going to do with it?
Automations?
Keep us posted
