Hi!
I am trying to add some Sonoff basic converted to Home Accessory Architect former Ravencore with the latest firmeware.
In my log I found the following entry as the Homekit devices didn’t get recognized.
Is there something I can/must change?
My setup is
RPI 3b+ with HassOS image
HA = 0.105.5
HA Core = 311(?)
URBANsUNITED
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 127, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 59, in post
handler, context={"source": config_entries.SOURCE_USER}
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 109, in async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 172, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py", line 107, in async_step_user
all_hosts = await self.hass.async_add_executor_job(self.controller.discover, 5)
File "/usr/local/lib/python3.7/site-packages/homekit/controller/controller.py", line 90, in discover
return discover_homekit_devices(max_seconds)
File "/usr/local/lib/python3.7/site-packages/homekit/zeroconf_impl/__init__.py", line 102, in discover_homekit_devices
info.properties
File "/usr/local/lib/python3.7/site-packages/homekit/zeroconf_impl/__init__.py", line 180, in parse_discovery_properties
d['category'] = Categories[int(category)]
File "/usr/local/lib/python3.7/site-packages/homekit/model/categories.py", line 94, in __getitem__
raise KeyError('Item {item} not found'.format(item=item))
KeyError: 'Item 31 not found'
