[Solved] Add last changed time as X hours/minutes ago
I like to add a last changed to a custom:mushroom-template card.
It’s for a simple open/closed sensor.
I did found a one-liner that will include the absolute time of the last change.
{{ as_timestamp(states.binary_sensor.front_door.last_changed,
  default=0)|timestamp_custom('%d.%m.%Y %H:%M', default=0) }}
But I’m looking for “x minutes/hours ago”.
As far as I know I need to use this template card the make the battery badge icon work.
If I use a entity-card the badge will not show up.
Here a image what I have now:
Hope someone can help me with this.
Bug thanks in advance.
The full code:
type: custom:mushroom-template-card
entity: binary_sensor.sliding_door
primary: Sliding door
secondary: >-
icon: |-
  {% if is_state("binary_sensor.sliding_door", "on") %}
    mdi:door-open
  {% elif is_state('binary_sensor.sliding_door', 'off') %}
    mdi:door-closed
  {% endif %}
badge_icon: |-
  {% if is_state('sensor.contact_sensor_battery_state', 'high') %}
    mdi:battery
  {% elif is_state('sensor.contact_sensor_battery_state', 'medium') %}
    mdi:battery-50
  {% elif is_state('sensor.contact_sensor_battery_state', 'low') %}
    mdi:battery-10
  {% endif %}
badge_color: |-
    green
    orange
    red
  {% endif %}
tap_action:
  action: more-info
hold_action:
  action: none
double_tap_action:
  action: none
icon_color: |-
  {% if is_state('binary_sensor.sliding_door', 'on') %}
    blue
  {% endif %}
Here is mine for my letterbox, just replace the variables with yours.
{{ relative_time(state_attr('automation.letterbox','last_triggered')) }} ago
Did not work right away, but could make it work.
Thanks for sharing.
Would you mind posting your solution or what is wrong with the above, so others can find and use it in the future? :slight_smile:
Thanks a lot! :slight_smile:
Sure,
I think the line Neil_Brownlee
could have worked but for some reason it didn’t.
But his line gave me a idea to try and after some googling I found this and changed it to fit my variables.
{{ (as_timestamp(now()) - as_timestamp(states.binary_sensor.front_door.last_changed | default(0)) | int ) | timestamp_custom("%Hh %Mm", false)}}
It looks like this now
{{ relative_time(states.input_boolean.pulizia_cucina.last_updated) }}
also this above worked for me.
