SOLVED - Add Picture icon to map (car icon)
on the map, I would like to put a picture of the people or of my car to show on the map.
Do you know :slight_smile:
  1. How do I upload the pictures
  2. How do I set this picture as the “device” on the map ?
I had a look at my devices, but found nowhere where to assign a “picture”. On the map for the moment it shows circles with the acronyms of the device.
Many thanks !
Map card (or Map view) shows entities with “latitude” & “longitude” attributes.
Usually images are set to “person” & “device_tracker” entities via customization.
For “person” entities it may be done in UI for “people”.
For “device_tracker” - only via yaml customization (somewhere here described).
Thanks a lot … this is to show the picture of my car on the map, instead of a circle with letters in it.
I have successfully put the picture in the www folder. it is accessible via /local/bmw-picture.png
I am wondering where I need to “map” this picture with the entity, now …
On the entity config itself, I can not assign it :
on the map itself, I can only see this :
… as you can see, it is only 4 lines … I think I need to put the link to the picture there somewhere ?
the link you mention is not helping lee that much
only this variant.
ok - I found out how to show my car’s picture on the Map card.
First, upload the picture (in png format from my side) in the HA, I did it using the “File editor” add-on I have installed. Using this, put the picture under “www”, so that is is accessible from “/local/”.
Then, edit the configuration.yaml adding this code :
homeassistant:
  customize: !include customize.yaml
… This is to call a “customize.yaml” config file. As it was not existing yet, I have created it at the same level of “configuration.yaml” like this :
then edit this customization.yaml and I have put the following code to assign the picture to the tracker tracker of my car :
device_tracker.225e_xdrive:
  entity_picture: /local/BMW-picture.png
… and magic, the icon is now showing on the map :
Hope it can help !
What are the purple lines? Do you keep track of the location history in this map card?
yes, indeed
I just wanted to let you know I finally got the time to follow your guide, and it works perfectly. Thanks for the support! next step is to enter the tracking lines on the map…
I step in for one final question, is there a trick to center the picture? I tried to put the car logo in and I could never manage to center it
What do you lean center a picture ?
the picture which is showed on the map will be the pone you have put in your config, centered in a circle …
that I mean
It´s not in the middle/centered and I don´t know how to adjust. I changed the resolution and tried a few things but no success
I guess you need to play a bit with the original picture, try to center it, see what part of the picture HA takes to put in the circle … see here is my original picture :
… and here is what I see on the map :
It looks like it take the left part of the original picture :wink:
Maybe if you make the original picture the correct size directly, it will be better (I see in some topics they talk about a picture of 192x192 pixels) …
… but I am happy with it
:wink:
Hi, I follow quite a few of your suggestions, always helpful…and apologies for the direct approach
In this case, I progressed quite a bit and am using a svg but… the picture continues to have the circle and white background. Would you have any idea how to circumvent this? When I am using icons for the gas-stations (they are of type ‘zone’) then it is fine.
Hints/tips/tricks/rejections/etc… all welcome :slight_smile:
EDIT: the buses are based on geo_json-created entries and then a customize_glob, should not matter but not sure.
Suggest to wait for 2025.1 )))
See if you can make it a png file, with no background …
It’s already a svg without…
Not sure if this is related to 2025.1 but I found the solution via trial and error …this using some of your pointers as I have only a little clue of what I am doing
Would you possibly explain me why this always needs the 'var() part? i.e. border: 0px or backgrond-color: none donot do a thing
card_mod:
  style:
    ha-map:
        .leaflet-marker-icon:
          ha-entity-marker $: |
            .marker {
              border: 0px solid var(--ha-marker-color,var(--primary-color)) !important;
              background-color: var(--ha-marker-color,none) !important;
You will have to wait for few days, I will be able to check it in a week probably…
So what is the correct way to do it, now that 2025.1 has been out and about for a while? :grin:
