Pulling my hair out. I’m trying to add a second Reolink camera to Frigate. I set it up and it works fine in a HACs custom Frigate card on my dashboard. I then tried to add it to my Frigate config file so it would be part of my Frigate NVR setup. But it clearly doesn’t recognize the camera name from Home Assistant, it shows as Red when I try to add Rooftop to the bottom of the Frigate config file. (Rooftop is the name of my new Reolink camera.) Here’s the config file:
mqtt:
host: 192.168.1.55
port: 1883
client_id: frigate
user: harryfine
password: Carrie_Feuer0HA
detectors:
cpu1:
type: cpu
birdseye:
enabled: true
width: 640
height: 480
quality: 8
mode: continuous
go2rtc:
streams:
reolink:
- http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=eibboR
- "ffmpeg:reolink#audio=opus"
reolink_sub:
- http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=eibboR
ffmpeg:
hwaccel_args: -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p
input_args:
- -avoid_negative_ts
- make_zero
- -fflags
- nobuffer+genpts+discardcorrupt
- -flags
- low_delay
- -strict
- experimental
- -analyzeduration
- 1000M
- -probesize
- 1000M
- -rw_timeout
- "5000000"
output_args:
record: preset-record-generic-audio-aac
detect:
enabled: True
width: 640
height: 480
fps: 5
record:
enabled: true
retain:
days: 3
mode: motion
events:
pre_capture: 5
post_capture: 5
retain:
default: 3
mode: active_objects
snapshots:
enabled: true
timestamp: true
bounding_box: true
retain:
default: 3
mode: all
objects:
person: 3
dog: 2
cameras:
reolink:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/reolink?video=copy&audio=aac
input_args: preset-rtsp-restream-low-latency
roles:
- record
- path: rtsp://127.0.0.1:8554/reolink_sub?video=copy
roles:
- detect
It runs perfectly, showing the one original camera in Frigate, then I try to add this new camera to the bottom:
Rooftop:
ffmpeg:
inputs:
roles:
- record
roles:
- detect
But it throws up errors when I try to save it. In System → Devices, there are two Reolink cameras shown…reolink and Rooftop, but the rooftop camera does not appear as a Frigate device. If you look at devices, it doesn’t show the Rooftop device as a Frigate child:
