I am fairly new to AppDaemon but trying to get it to execute a simple py script that relies on a python package (Anki Vector SDK) that I have installed via configuration tab - I have also confirmed it is working: If I use Portainer to access the AppDaemon container after it has installed the package, I can run a simple py script (see below) via the console that sends Hello World to Vector.
import anki_vector
def main():
args = anki_vector.util.parse_command_args()
with anki_vector.Robot(args.serial) as robot:
print("Say 'Hello World'...")
robot.behavior.say_text("Hello World")
if __name__ == "__main__":
main()
Now if I try to do the same via AppDaemon with a modified py script for when I fire an event called
VECTOR_EVENT
It will crash and go in a loop.
import appdaemon.plugins.hass.hassapi as hass
import anki_vector
class VectorWorld(hass.Hass):
def initialize(self):
self.listen_event(self.vector_event, "VECTOR_EVENT")
def vector_event(self, event_name, data, kwargs):
self.log("Vector SDK...")
This is an extract from the logs:
2022-02-20 16:22:42.180979 INFO vector_test: Vector SDK…
usage: appdaemon [-h] [-s [SERIAL]]
appdaemon: error: unrecognized arguments: -c /config/appdaemon -D INFO
2022-02-20 16:22:42.714415 CRITICAL AppDaemon: Thread thread-0 has died
2022-02-20 16:22:42.721532 CRITICAL AppDaemon: Pinned apps were: [‘vector_test’]
2022-02-20 16:22:42.722532 CRITICAL AppDaemon: Thread will be restarted
What does the above in bold mean
