SOLVED - Alarm Control Panel not displayed ( UI error Entity not available )
Hi ,
I would like to build an alarm panel so I started by this documentation https://www.home-assistant.io/integrations/manual/
  1. The following configuration example is not working in 0.112 version as per the check Home Assistant configuration ( HassOS 4.11)
# Example configuration.yaml entry
alarm_control_panel:
  - platform: manual
    code: '1234'
    arming_time: 30
    delay_time: 20
    trigger_time: 4
    disarmed:
      trigger_time: 0
    armed_home:
      arming_time: 0
      delay_time: 0
UI Configuration of Alarm Panel
type: alarm-panel
states:
  - arm_home
  - arm_away
entity: alarm_control_panel.house_alarm
UI Error message following the integration of Alarm Panel card
Entity not available: alarm_control_panel.house_alarm
Check Home Assistant Configuration errrors messages :
[18:56:47] ERROR: The configuration check did not pass!
[18:56:47] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Failed config
  General Errors:
    - Component error: alarm - Integration 'alarm' not found.
  1. There is nothing to configure from the UI ( Configuration / integration menu)
An alarm panel has not been added in the Home assistant UI
  1. Is it a known problem in 0.112 Version ?
Thank you for the guidance
Same with the update 0.113
I assume your entity is actually called alarm_control_panel.house_alarm and not alarm_control_panel.house.alarm.
Have you checked your entities list in Configuration -> Entities. ?
This leads me to believe you have the below defined in your configuration.yaml
alarm:
  # possibly some config here
Thank you @MatthewFlamm for your answers.
  1. Concerning the entity , yes it is actually called alarm_control_panel.house_alarm and not alarm_control_panel.house.alarm .
    I did many tests and was confused when created the 1st post
    ==>> 1st post corrected
There is no alarm entity in configuration/Entities menu !
  1. Concerning the Component error: alarm - Integration 'alarm' not found , in the configuration.yaml file there is no “alarm:” but an include file called alarm.yaml
I have tested some other integrations and i got the same problem so it cant be a general problem in HA as nobody confirmed , so I do not know what i am missing for the configuration !
Can you share this config? I suspect this is the issue.
Sure ,
  • config/configuration.yaml
alarm: !include alarm.yaml
  • config/alarm.yaml
# Alarm System
# Alarm Panel
  - platform: manual
    code: '1234'
    arming_time: 30
    delay_time: 20
    trigger_time: 4
    disarmed:
      trigger_time: 0
    armed_home:
      arming_time: 0
      delay_time: 0
You need to use:
alarm_control_panel : !include alarm.yaml
Then get rid of the alarm_control_panel line inside the file and adjust the indentation accordingly.
Thank you very much for the solution to my wrong understanding of the splitting up of the configuration .
It works now as expected … and I can play with this promising HA app.
:smile:
I
