Compiling /data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_icons.cpp.o
Compiling /data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_screen.cpp.o
Compiling /data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_store.cpp.o
In file included from src/esphome.h:25,
from src/esphome/components/ehmtx/EHMTX.cpp:1:
src/esphome/components/ehmtx/EHMTX.h:6:10: fatal error: esphome/components/animation/animation.h: No such file or directory
#include "esphome/components/animation/animation.h"
compilation terminated.
*** [/data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX.cpp.o] Error 1
from src/esphome/components/ehmtx/EHMTX_icons.cpp:1:
*** [/data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_icons.cpp.o] Error 1
from src/esphome/components/ehmtx/EHMTX_screen.cpp:1:
*** [/data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_screen.cpp.o] Error 1
from src/esphome/components/ehmtx/EHMTX_store.cpp:1:
*** [/data/ulanzi/.pioenvs/ulanzi/src/esphome/components/ehmtx/EHMTX_store.cpp.o] Error 1
========================= [FAILED] Took 112.91 seconds =========================
To make sure it’s not my Home Assistant, I installed an esphome Docker on a completely different machine.
The result is exact the same.
I hope this is the proper way, because in my project folder was an “read_me” with this content:
THIS DIRECTORY IS AUTO-GENERATED, DO NOT MODIFY
ESPHome automatically populates the build directory, and any
changes to this directory will be removed the next time esphome is
run.
For modifying esphome's core files, please use a development esphome install,
the custom_components folder or the external_components feature.
but unless someone sees this that has used the component you may struggle to find an answer. On the GitHub for that component there is a issue re breaking change and including a dummy animation component - maybe that’s a clue.
Furthermore you must add the picture “black.gif” in the esp home folder e. g. /config/esphome/
This picture is an easy 1x1 px black gif file.
I guess it must be a gif, because an animation is only possible with a gif.
Only now the compiler will use the files animation.h,… will be used.
