Hi guys! I’m a newbie and I’ve some troubles with my configuration.
Every second, I’d like to set a new temperature based on an user input value, if time-range conditions are true.
See my code below, here just some informations about inputs:
in input_number.myownheater_temperature are saved a new temperature
input_datetime.myownheater_time_from and input_datetime.myownheater_time_to are time-only inputs
alias: MyOwnHeater
- seconds: /1
platform: time
condition:
- condition: template
value_template: '{{ strptime(states.input_datetime.myownheater_time_from, "%H-%i") <= strptime(now(), "%H-%i") }}'
value_template: '{{ strptime(now(), "%H-%i") < strptime(states.input_datetime.myownheater_time_to, "%H-%i") }}'
- data_template:
entity_id: climate.myownheater
temperature: '{{ states.input_number.myownheater_temperature.state }}'
service: climate.set_temperature
- data: {}
service: climate.turn_on
In example, I’d like to set 21°C and turn on automatically my own heater from 10:00pm to 12:00pm, so:
- input_number.myownheater_temperature contains 21.0°C
- input_datetime.myownheater_time_from contains 10:00pm
- input_datetime.myownheater_time_to contains 12:00pm
Can you help me, please?
Do you get any errors when the automation fires? I’m not sure if it was a typo or not, but the indenting in your conditions looks wrong.
Nope, no errors in configuration check or after reboot, but this automation is never trigger.
I don’t know if it’s required, but when I use time triggers, I put the “/1” in quotes.
I’ve modified automation with “/1” and I’ve also changed my conditions template from “%H-%i” to “%H:%M”, according to strptime() format, but it’s not triggered.
If I configure my automation.yaml with explicit times it works perfectly, in example with ‘10:00’ or ‘12:00’
Ahhh… that helped point me in the right direction. I was missing it too.
needs to be
states.input_datetime.myownheater_time_to.state
and
needs to be
states.input_datetime.myownheater_time_from.state
Nothing to do…I think that conditions are written in a wrong way (semantically), but I don’t know how to fix them.
Here the updated configuration:
alias: MyOwnHeater
- seconds: "/1"
platform: time
condition:
value_template: '{{ strptime(states.input_datetime.myownheater_time_from.state, "%H:%M") <= strptime(now(), "%H:%M") }}'
value_template: '{{ strptime(now(), "%H:%M") < strptime(states.input_datetime.myownheater_time_to.state, "%H:%M") }}'
- data_template:
- data: {}
Indentation is incorrect in your first action.
You have no service data for your second action.
- data_template:
- data:
some_key_here: #entity_id most likely, or something, and probably a parameter or two.
I also suspect that the actions should be the other way around?
Try this…
alias: MyOwnHeater
- seconds: "/1"
platform: time
condition:
value_template: >-
{{ as_timestamp(now()) | timestamp_custom('%H%M') | int < state_attr('input_datetime.myownheater_time_to','timestamp') | timestamp_custom('%H%M') | int }}
value_template: >-
{{ state_attr('input_datetime.myownheater_time_from','timestamp') | timestamp_custom('%H%M') | int <= as_timestamp(now()) | timestamp_custom('%H%M') }}
- data_template:
- data: {}
Your last solution doesn’t work, unluckily… but I had found a solution!!
It’s composed by 2 step:
- first, I checked the value of “time_zone” in configuration.yaml and it was not correct (now it’s Europe/Rome and it’s correct)
- second, after some logs, I found a very useful example that solved my problem (you can see it in the code below)
This is my last version of code in automations.yaml:
- alias: "MyOwnHeater"
- seconds: '/1'
platform: time
condition:
value_template: >
{% set ts = states.input_datetime.myownheater_time_from.attributes.timestamp %}
{% set midnight = as_timestamp("%d-%d-%d 00:00:00" | format(now().year, now().month, now().day)) %}
{{ now().strftime("%H:%M") >= (midnight + ts) | timestamp_custom("%02H:%02M", 1) }}
value_template: >
{% set ts = states.input_datetime.myownheater_time_to.attributes.timestamp %}
{{ now().strftime("%H:%M") < (midnight + ts) | timestamp_custom("%02H:%02M", 1) }}
- data_template:
temperature: '{{ states.input_number.myownheater_temperature.state | float }}'
- data:
Thank you very much for your support!
Ahhh… so it had to do with the value stored in the input_datetime entities. Makes sense. I’ve never used those, so I was approaching it from the other side.
Also worth noting… with a time trigger of “/1” seconds, this trigger is literally running every single second. No matter what you run Home Assistant on, this is surely a waste of CPU.
You can change the trigger on this to save some CPU, and add a second trigger to get an instant effect if someone changes the input_number.
Outside of that, every 5 minutes seems pretty reasonable.
So, triggers, maybe, like this instead…
- platform: state
entity_id: input_number.myownheater_temperature
- platform: time:
second: '00'
minutes: '/5'
Either way, I’m glad you found a working solution.
Ah ok, extending running time is a good suggestion
I think that I’ll keep a real-time feedback from Hass.io during studing and automations developing phases and I’ll change to 5 minutes the trigger in production mode.
Thank you very much!
