the error checker gets messed up sometimes and gives the wrong (or no) line numbers depending on how your config is split up.
but as deluxestyle pointed out the error is in the automations (as noted in the error wording itself) not the groups (as indicated by the line number).
it looks like in the action you are referencing a trigger but it doesn’t exist yet? without seeing the automation it’s hard to tell why it would be like that.
I went through all automations and they seem to be fine. I have a few turned off that can’t work right now but other than that I have no idea. I am attaching my automations.yaml in case someone sees something glaringly obvious.
- id: '1556163979419'
alias: Set Heat During Day
- at: 07:00:00
platform: time
condition:
- below: '69'
condition: numeric_state
entity_id: sensor.liberty_hill_inside_temp
- data:
temperature: 69
hvac_mode: heat
service: climate.set_temperature
entity_id:
- climate.z_wave_thermostat_3
- id: '1556164126979'
alias: Set Heat at Night
- at: '20:00:00'
platform: time
condition:
- above: '69'
- data:
temperature: 65
hvac_mode: heat
entity_id:
- id: '1556166051078'
alias: Turn On AC
- above: '75'
platform: numeric_state
condition: []
- data:
hvac_mode: cool
temperature: 69
entity_id:
- id: '1592963383196'
alias: Close Double Garage Door
description: Put the double garage door down at night
- event: sunset
platform: sun
condition:
- condition: state
entity_id: cover.double_garage
state: open
- service: cover.close_cover
entity_id:
- cover.double_garage
mode: single
- id: '1592963953246'
alias: Close Single Garage Door
- event: sunset
platform: sun
condition:
- condition: state
entity_id: cover.single_garage
state: open
entity_id:
- cover.single_garage
mode: single
- id: '1593037112136'
alias: Turn landscape lighting on
description: Turns the low voltage lights on outside of Saddlewood
- event: sunset
platform: sun
offset: +00:30:00
condition:
- condition: state
state: 'off'
entity_id: switch.smart_switch_6_current_value
- type: turn_on
device_id: 16b5e66a82158ab2a470a2c59f35507c
domain: switch
mode: single
- id: '1593037252264'
alias: Turn landscape lighting off
description: Turns the low voltage lights off outside of Saddlewood
- event: sunrise
offset: -04:00:00
platform: sun
condition:
- condition: state
state: 'on'
- type: turn_off
domain: switch
mode: single
- id: '1605361985322'
alias: Turn Smart Switches On (Sunset)
description: Turn on smart switches at sunset.
- platform: sun
event: sunset
offset: +00:30:00
condition: []
- type: turn_on
device_id: 4319a2dfcc2c06db27567dad58f82a46
entity_id: switch.smart_switch_6_current_value_3
domain: switch
- type: turn_on
device_id: ca9ea528c97ee15bfd5226a9d479b092
entity_id: switch.smart_switch_6_current_value_2
domain: switch
- type: turn_on
device_id: 5579254333087d1fe50c5a2c7987f7bf
entity_id: switch.wall_plug_switch_current_value
domain: switch
- service: ifttt.trigger
event: porch_lights_on
value1: 'on'
- type: turn_on
device_id: 8efc2e84e5887c844e3aa7b65291ca99
entity_id: switch.none_current_value
domain: switch
- type: turn_on
device_id: 751dd369c58726d884cef8f3c8932e43
entity_id: switch.outdoor_z_wave_plug_in_module_2_channel
domain: switch
mode: single
- id: '1605362102253'
alias: Turn Smart Switches Off (Before Sunrise)
description: Turn off Smart Switches 5 hours before sunrise.
- platform: sun
event: sunrise
offset: -05:00:00
condition: []
- type: turn_off
domain: switch
- type: turn_off
domain: switch
- type: turn_off
domain: switch
event: porch_lights_off
value1: 'false'
- type: turn_off
domain: switch
- type: turn_off
domain: switch
mode: single
- id: '1613838752640'
alias: Maintain Humidity - Off
description: Optimal humidity in winter by toggling the humidifier off in ideal
conditions.
- platform: state
entity_id: sensor.average_house_rh_2
- platform: state
entity_id: sensor.liberty_hill_temp
condition:
- condition: device
type: is_on
device_id: 0bc7fc57176e25715459e733d2f31b89
entity_id: switch.flush_1d_relay_current_value_2
domain: switch
- condition: or
conditions:
- condition: and
conditions:
- condition: numeric_state
above: '35'
below: '40'
above: '20'
below: '50'
- condition: and
conditions:
above: '30'
below: '35'
above: '10'
below: '20'
- condition: and
conditions:
above: '25'
below: '30'
above: '0'
below: '10'
- condition: and
conditions:
above: '20'
below: '25'
above: '-10'
below: '0'
- condition: and
conditions:
above: '15'
below: '20'
above: '-20'
below: '-10'
- condition: and
conditions:
above: '15'
below: '-20'
- condition: and
conditions:
above: '50'
above: '50'
- type: turn_off
domain: switch
mode: single
- id: '1613838885619'
alias: Maintain Humidity - On
description: "Optimal humidity in winter by toggling the humidifier on in non-ideal\n\
\ conditions."
- platform: state
- platform: state
condition:
- condition: device
type: is_off
domain: switch
- condition: or
conditions:
- condition: and
conditions:
below: '35'
above: '20'
below: '50'
- condition: and
conditions:
below: '30'
above: '10'
below: '20'
- condition: and
conditions:
below: '25'
above: '0'
below: '10'
- condition: and
conditions:
below: '20'
above: '-10'
below: '0'
- condition: and
conditions:
below: '15'
above: '-20'
below: '-10'
- condition: and
conditions:
below: '15'
below: '-20'
- condition: and
conditions:
below: '50'
above: '50'
- condition: state
entity_id: climate.z_wave_thermostat
state: heat
- type: turn_on
domain: switch
mode: single
- id: '1615067351970'
- id: '1615068934627'
alias: Refresh Humidity Sensors
description: ''
- platform: state
entity_id: sensor.liberty_hill_humidity_in
condition: []
- service: zwave_js.refresh_value
entity_id: sensor.z_wave_thermostat_humidity_2
entity_id: sensor.z_wave_thermostat_humidity_2_2
entity_id: sensor.multisensor_6_humidity_2
mode: single
- id: '1618075982150'
alias: When I leave home send Eugene to clean
description: ''
- platform: zone
entity_id: person.john_lento
zone: zone.home
event: leave
- platform: zone
entity_id: person.jennifer_lento
zone: zone.home
event: leave
condition:
- condition: device
device_id: eb74300e7100e75b9ca811f548efb5cb
domain: vacuum
entity_id: vacuum.eugene
type: is_docked
- device_id: eb74300e7100e75b9ca811f548efb5cb
domain: vacuum
type: clean
mode: single
- id: '1618089952617'
alias: When I return home send Eugene home
description: ''
- platform: zone
zone: zone.home
event: enter
- platform: zone
zone: zone.home
event: enter
condition:
- condition: device
domain: vacuum
type: is_cleaning
domain: vacuum
type: dock
mode: single
- id: '1618146215816'
alias: Turn off Humidifier
description: Turns off the humidifier when HVAC is set to off or cold.
- platform: state
to: 'off'
- platform: state
to: cool
- platform: state
to: cool
condition:
- condition: device
type: is_on
domain: switch
- type: turn_off
domain: switch
mode: single
- id: '1618636288270'
alias: Open Double Garage Door at Sunrise
description: ''
- platform: sun
event: sunrise
condition:
- condition: state
state: closed
- service: cover.open_cover
mode: single
- id: '1632185494706'
alias: Turn pool lights on
description: ''
- platform: sun
event: sunset
condition:
- condition: device
type: is_off
device_id: f3dba731a645554c0ff1f58307a977c0
entity_id: light.pool_lights
domain: light
- type: turn_on
domain: light
mode: single
- id: '1632185572234'
alias: Turn pool lights off
description: ''
- platform: sun
event: sunrise
offset: -04:00:00
condition:
- condition: device
type: is_on
domain: light
- type: turn_off
domain: light
mode: single
