Ares
(guillaume)
October 29, 2018, 1:45am
1
I don’t understand why this automation doesn’t work:
- id: '1523312703890'
alias: Lumière auto Aquarium
- platform: time
at: '02:38:00'
- entity_id: switch.lumiereAquarium
service: switch.turn_on
- delay: 00:00:02
service: switch.turn_off
I can manually trigger it on the dashboard, but the time function doesn’t trigger it
Thank you in advance
tom_l
October 29, 2018, 1:51am
2
In the dev tools template editor, does the following:
{{ now() }}
return the correct time?
Ares
(guillaume)
October 29, 2018, 1:54am
3
well… thank you I found the problem…
2018-10-29 01:52:10.408312+00:00
How can I change it ?
I got baited by:
tom_l
October 29, 2018, 1:57am
4
That is actually the correct UTC time. Have you configured a time zone?
Ares
(guillaume)
October 29, 2018, 2:02am
5
No, I’m on UTC + 1:00 I changed the time zone on my configuration and it works well…
The thing is on the history dashboard the time was correct…
Thank you a lot
tom_l
October 29, 2018, 2:14am
6
That’s odd. I would expect the geoip time zone (that HA uses if no time zone is defined) to be global.
Set up the other basic config stuff while you’re there:
