[SOLVED] Automations with Philips dimmer switch using z2mqtt help
I recently just moved all of my devices from ZHA to Z2mqtt and noticed that my Philips dimmer switch is not showing all the different button actions like I see in ZHA (turn on, turn off, hold, etc) when I select device triggers in automation & scenes. Inside my z2mqtt, I see the switch exposed battery %, action N/A, and link quality number. What am I missing to get the actions to show up in automation pull down menu?
EDIT: After some digging, it’s likely the Philips switch and motion sensors are not compatible with my Sonoff 3 Dongle Plus usb stick.
