So I am migrating my installation from TrueNAS (FreeBSD) to Armbian. Both are HA core installations. I have a card on my dashboard that streamed my doorbell camera. It is an Amcrest and I have it configured to use rtsp in the configuration.yaml. On the new system, if I set the card to auto, it will show a still image from the camera. But when set to live, it looks like the image below.
I have these errors in my log that may be related.
File "/srv/homeassistant/lib/python3.10/site-packages/haffmpeg/core.py", line 136, in open
self._proc = await self._loop.run_in_executor(None, proc_func)
File "/usr/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3.10/subprocess.py", line 966, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib/python3.10/subprocess.py", line 1842, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
2022-08-11 19:51:27.084 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
2022-08-11 19:51:27.088 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/srv/homeassistant/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/camera/__init__.py", line 729, in get
return await self.handle(request, camera)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/camera/__init__.py", line 769, in handle
stream = await camera.handle_async_mjpeg_stream(request)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/amcrest/camera.py", line 272, in handle_async_mjpeg_stream
stream_reader = await stream.get_reader()
File "/srv/homeassistant/lib/python3.10/site-packages/haffmpeg/core.py", line 181, in get_reader
lambda: reader_protocol, self._proc.stdout
AttributeError: 'NoneType' object has no attribute 'stdout'
