[SOLVED] Can not open UI node red hassio
I am new to node red.
I am trying to get node red to open UI interface after install but nothing works.
What am I doing wrong ?
This is the config:
“log_level”: “info”,
“credential_secret”: “”,
“dark_mode”: false,
“http_node”: {
“username”: “”,
“password”: “”
“http_static”: {
“username”: “”,
“password”: “”
“port”: 1880,
“ssl”: false,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“require_ssl”: true,
“system_packages”: [],
“npm_packages”: [],
“init_commands”: []
This is the Log:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Hass.io Add-on: Node-RED v1.3.4
Flow-based programming for the Internet of Things
By: Franck Nijhof [email protected]
amd64 / Ubuntu 18.10 / HA 0.89.1 / SU 148 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing…
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing…
FATAL: Setting a credential_secret is REQUIRED!
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
            Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Seems it very plainly states what the problem is.
Thanks.
Workong now.
I changed some of config:
“credential_secret”: “XXXXX”,
“dark_mode”: false,
“http_node”: {
“username”: “”,
“password”: “”
“http_static”: {
“username”: “”,
“password”: “”
“port”: 1880,
“ssl”: false,
“require_ssl”: false,
“npm_packages”: [],
“init_commands”: []
