Hello All. I am having a bit of trouble and I hope someone can help.
I have just purchased a new ConBee II device. I initially added the device to HA using deCONZ add-on via Supervisor and everything went well. For my part though, I didn’t like the non integrated look and feel and then noticed that HA itself had found my device automatically and there was an official integration.
core-2021.9.1
supervisor-2021.08.1
Unfortunately I cannot get past the initial setup of the device via the official integration.
If I try and Setup via the Wizard after automatic discovery:
- Go through to Integrations via Notifications
- Click Configure
- Box asks “Do you want to setup ConBee II - /dev/serial/by-id/usb dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II etc…”
- Click Submit
- Spinning Blue Circle where the Submit button was
- Box comes up after about a minute saying “Aborted”
If I try and setup by adding an Integration:
- Add Integration>Zigbee Home Automation
- Box comes up asking me to choose device serial path (3 in list, one is Add Manually)
- Select only option that makes sense “/dev/ttyACM0 - ConBee II etc …” and Submit (not this is note a /dev path as per the first method which is what I would be expecting)
- After what appears to be a fair while
- Box appears to choose Radio Type. Choose deCONZ and Submit.
- Box appears asking me to choose device serial path (again), this time the path is a /dev/serial/by-id/usb-dresden etc … path
- Click Submit and get an error “Failed to Connect”
Things I have tried:
- Grabbing the /dev/ path from the command line and adding Manually (thus avoiding the /tty paths) - same result
- Using the /tty path exclusively - same result
My Logs show:
Method 1:
Retry command 0x0002
1:49:51 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_zigate/api.py
No response to command 0x0002
No response to ‘Command.device_state’ command with seq id ‘0x02’
1:49:50 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py
Method 2:
1:53:02 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - message first occurred at 1:52:03 PM and shows up 2 times
No response for: SRSP SYS version {}
1:52:10 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_cc/api.py
at: No response to AP command
1:52:09 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_xbee/api.py
1:52:07 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_zigate/api.py
