(SOLVED) Cannot add Eltako EUD62NPN-IPM
I have been trying to add a new module I received :
Eltako EUD62NPN-IPM/110-240V
It’s a light dimmer.
When comissionning the device fails at the last step (after connectivity check).
I have tried to reset it with no lucks.
I also tried with the android popup (when a new matter devices is discovered), it’s possible to add it to HA, I can see that my phone transmit the credentials and all, but it fails when adding the device to HA at the screen below :
I know my thread network works fine because I have Eve and sonoff devices connected over Matter.
Does anyone have a work around ?
Pierre.
I have found a sort of solution.
I was using the Home Assistant SkyConnect.
I then used a Sonoff ZBDongle-E flashed with firmware (thread) 2.4.1.0 (460800)
I then reinstalled averything from a fresh backup and voila it is connecting.
In conclusion : I will not use NabuCasa Skyconnect.
