SOLVED: Cannot setup z-wave on new install of HA with Nortek HubZ
When I try to start the z-wave integration on the HubZ device, I get the folllowing error:
“ERROR (SyncWorker_1) [supervisor.docker] Image homeassistant/aarch64-addon-zwave_js not exists for addon_core_zwave_js”
The Zigbee integration started just fine. I have the “Z-Wave JS” addon installed, but it fails to start with the same error message.
I’m stumped.
Edit… I’m running Home Assistant core-2021.11.3, supervisor-2021.10.8, Home Assistant OS 7.0.rc1 on a raspberry pi 3 B+. I was getting the same issue on 2021.11.1.
Edit 2… Turns out the power supply for the PI was underpowered and that caused the addon install to fail. I guess it was intermittent, since other addons were able to be installed without issue. :man_shrugging:
