I’ve gotten a 2.9" waveshare e-ink display, the one in the example in the docs (trying to minimize any mistakes).
I’ve hooked it up to a D1 mini.
I’ve uploaded the code to the D1 mini, including a font and everything.
The code is just the ‘Hello World’ example, again keeping everything as basic as possible to start with.
But when I power it up, I don’t see the D1 mini coming online, and the display is not showing anything.
If I disconnect the display it boots up, and it comes online, and I can see the logs in esphome, but it complains about timeout on the display (of course).
I can of course build the d1mini without anything, then it just idles, so the d1mini works in itself.
This is my config:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "SSID"
password: "PW"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
font:
- file: "comic.ttf"
spi:
clk_pin: D0
mosi_pin: D1
display:
- platform: waveshare_epaper
cs_pin: D2
dc_pin: D3
busy_pin: D4
reset_pin: D5
model: 2.90in
full_update_every: 30
lambda: |-
it.print(0, 0, id(comic), "Hello World!");
