Hi all zwave lovers out there.
Like I say in the subject I have a weird situation where one of the 4 machines with zwave I’ve setup for family and friends does not present a QR code/smartstart option to add a zwave device.
Only noticed when trying to add a windows sensor that is the first battery powered device at that location. The same sensors as I have at my home that I was only able to add when using the QR code option.
I’ve compared the 2 machines configuration.yaml and things look correct but I must be missing some component that smartstart requires.
Any ideas? Screenshot attached from problem machine…
![image](https://community-assets.home-assistant.io/original/4X/a/f/a/afab448a81ef5263208488272edda32937bb4901.png)
and the option is just not there. Screenshot from my working machine…
![image](https://community-assets.home-assistant.io/original/4X/b/c/e/bce6333f4ed6193002308fb54a5d1229aceffd33.png)
Thanks in advance! ![:beers: :beers:](https://community.home-assistant.io/images/emoji/twitter/beers.png?v=10)
I should have mentioned - All systems running the official Z-Wave JS addon - up to date supervised installs on raspberry pis.
Are doing this from the app or a web browser? Try clearing your cache.
Multiple browsers tried - I’m able to remote in using my PC but the machine at that house did the same.
App also failed to present my friend the QR option but unfortunately I don’t have the app available to me as this is not my house.
Thanks for the reply tho - always good to start fresh
You have not mentioned what controllers you are using. Are they identical? SmartStart is not supported in older controllers. For example, the Nortek HUSBZB-1 and Aeotec Gen5 with fw < 1.2.
Another valid point - the 2 systems I took screenshots from both use Aeotec Z-Stick Gen5+
ZW090
by AEON Labs
Firmware: 1.2
Ah-ha! The problem location seems to need the latest firmware update.
ZW090
by AEON Labs
Firmware: 1.1
Thanks for that pro tip freshcoat.
Will try to get that updated this weekend and mark this solved if that makes the magic happen.
