Hi everybody,
this is more python related than just Home Assistant, I hope it is okay to post this anyway.
I am trying to write a python script to determine whether or not today is a particular (pre-defined) date, and, if so, print it; this printed value will be used as a sensor, which I want to work further with via Home Assistant automation.
My attempts are below; would somebody please help me finish the script?
first attempt
works, but I don’t like having countless variables
#!/usr/bin/env python3
import time
today = time.strftime("%d-%m")
halloween = "31-10"
test = "14-09"
if (heute == halloween):
print("Halloween")
elif (heute == test):
print("it worked!")
else:
print("nope.")
print(heute)
print(test)
This will output
It worked.
14-09
14-09
I could change the print statements accordingly and already have the sensor I want, however, this would require a variable for each date I want to define and a custom print statement for each case in the loop.
So I tried the following
import time
import json
mydays = {
"test": "14-09",
"halloween": "31-10"
for name, date in mydays.items():
This is where I cannot continue. I tried some things, but none of those work (don’t have any previous python knowledge).
The goal here is to see if the variable today
is equal to any value in the json; if so, print the according key to that value. So if today is equal to value of test, print test
; if today is equal to halloween (31-10), print halloween
Thank you for your ideas
