I have a command line binary sensor to check for HTTP status code from some of my locally running applications. For example, this is for checking HTTP status code for Grafana:
curl -I http://192.168.86.45:3000 2>/dev/null | head -n 1 | cut -d$' ' -f2
This returns 302, which is a successful HTTP status code. In my binary sensor configuration file I have the following sensor code set up:
- platform: command_line
command: "curl -I http://192.168.86.45:3000 2>/dev/null | head -n 1 | cut -d$' ' -f2"
value_template: >
{% if value | int in [200, 301, 302, 303, 304, 307] -%}
on
{%- else -%}
off
{%- endif %}
scan_interval: 300
device_class: connectivity
I tested the code with the template tool in Developer Tools tab, and the if check should work, but the sensor is always reporting Disconnected.
I also tried running the command logged in over SSH, and that works fine.
What is wrong with my code?
