[Solved !] Compilation issue on a basic sketch!
Hi
Using since a long time ESPHome in hassio I had no issue till now. Today I created a new sketch (based on an existing one) where I commented out most of code keeping just basic for now time to determine logic of this new node.
When I try to compile it it generates a very large qtity of errors (see below). If I compile any of my other existing sketches no problem, only this one does that ! Any ideas ?
Here is the sketch:
esphome:
  platform: esp8266
  board: d1_mini_pro
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_passwd
  fast_connect: True
  reboot_timeout: 60min
  manual_ip:
    static_ip: !secret ip_radiateur_vincen
    gateway: 192.168.1.1
    subnet: 255.255.255.0
api:
logger:
ota:
web_server:
dallas:
  - pin: D6
  - platform: uptime
    filters:
      - lambda: return x / 86400.0;
    unit_of_measurement: "days"
    accuracy_decimals: 0
#  - platform: dallas
#    address: 0x230417C0052EFF28
#    name: "Grenier"
# binary_sensor:
#  - platform: gpio
#    pin:
#      number: GPIO14
#    id: "bouton"
#    name: "Présence Grenier"
#    on_press:
#      then:
#        - switch.turn_on: relay
#    on_release:
#      then:
#        - script.execute: script_minuterie
#switch:
#  - platform: gpio
#    name: "Éclairage Machine à Laver"
#    pin: GPIO4
#    id: "relay"
#script:
#  - id: script_minuterie
#    then:
#      - delay: 20s
#      - switch.turn_off: relay
logs in next message (limit of size post !!)
and here are errors log of ESPHome when trying to compile (side note: the editor doesn’t notice any errors and validation goes fine !):
Dependency Graph
|-- <ArduinoJson-esphomelib> 5.13.3
|-- <ESP Async WebServer> 1.1.1
|   |-- <ESPAsyncTCP> 1.2.2
|   |   |-- <ESP8266WiFi> 1.0
|   |-- <Hash> 1.0
|-- <ESP8266mDNS>
|-- <ESPAsyncTCP> 1.2.0
Linking /data/radiateur_vincen/.pioenvs/radiateur_vincen/firmware.elf
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_recvEPvP7tcp_pcbP4pbufl+0x4): multiple definition of `AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, long)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_recvEPvP7tcp_pcbP4pbufl+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_sent(void*, tcp_pcb*, unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_sentEPvP7tcp_pcbt+0x4): multiple definition of `AsyncClient::_s_sent(void*, tcp_pcb*, unsigned short)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_sentEPvP7tcp_pcbt+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_error(void*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8_s_errorEPvl+0x4): multiple definition of `AsyncClient::_s_error(void*, long)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8_s_errorEPvl+0xc): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_poll(void*, tcp_pcb*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_pollEPvP7tcp_pcb+0x4): multiple definition of `AsyncClient::_s_poll(void*, tcp_pcb*)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_pollEPvP7tcp_pcb+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::AsyncClient(tcp_pcb*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClientC2EP7tcp_pcb+0x30): multiple definition of `AsyncClient::AsyncClient(tcp_pcb*)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClientC2EP7tcp_pcb+0x48): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_connected(void*, void*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12_s_connectedEPvS0_l+0x4): multiple definition of `AsyncClient::_s_connected(void*, void*, long)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12_s_connectedEPvS0_l+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::connect(IPAddress, unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7connectE9IPAddresst+0x18): multiple definition of `AsyncClient::connect(IPAddress, unsigned short)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7connectE9IPAddresst+0x1c): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_dns_found(char const*, ip_addr const*, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12_s_dns_foundEPKcPK7ip_addrPv+0x4): multiple definition of `AsyncClient::_s_dns_found(char const*, ip_addr const*, void*)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12_s_dns_foundEPKcPK7ip_addrPv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::connect(char const*, unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7connectEPKct+0x10): multiple definition of `AsyncClient::connect(char const*, unsigned short)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7connectEPKct+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::operator==(AsyncClient const&)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClienteqERKS_+0x0): multiple definition of `AsyncClient::operator==(AsyncClient const&)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClienteqERKS_+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::abort()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5abortEv+0x4): multiple definition of `AsyncClient::abort()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5abortEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::free()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient4freeEv+0x4): multiple definition of `AsyncClient::free()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient4freeEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::send()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient4sendEv+0x8): multiple definition of `AsyncClient::send()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient4sendEv+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::ack(unsigned int)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient3ackEj+0x4): multiple definition of `AsyncClient::ack(unsigned int)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient3ackEj+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::operator+=(AsyncClient const&)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClientpLERKS_+0x0): multiple definition of `AsyncClient::operator+=(AsyncClient const&)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClientpLERKS_+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::setRxTimeout(unsigned int)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12setRxTimeoutEj+0x0): multiple definition of `AsyncClient::setRxTimeout(unsigned int)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12setRxTimeoutEj+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getRxTimeout()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12getRxTimeoutEv+0x0): multiple definition of `AsyncClient::getRxTimeout()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12getRxTimeoutEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getAckTimeout()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13getAckTimeoutEv+0x0): multiple definition of `AsyncClient::getAckTimeout()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13getAckTimeoutEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::setAckTimeout(unsigned int)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13setAckTimeoutEj+0x0): multiple definition of `AsyncClient::setAckTimeout(unsigned int)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13setAckTimeoutEj+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::setNoDelay(bool)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10setNoDelayEb+0x0): multiple definition of `AsyncClient::setNoDelay(bool)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10setNoDelayEb+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getNoDelay()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10getNoDelayEv+0x0): multiple definition of `AsyncClient::getNoDelay()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10getNoDelayEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getMss()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6getMssEv+0x0): multiple definition of `AsyncClient::getMss()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6getMssEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getRemoteAddress()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient16getRemoteAddressEv+0x0): multiple definition of `AsyncClient::getRemoteAddress()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient16getRemoteAddressEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getRemotePort()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13getRemotePortEv+0x0): multiple definition of `AsyncClient::getRemotePort()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13getRemotePortEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getLocalAddress()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient15getLocalAddressEv+0x0): multiple definition of `AsyncClient::getLocalAddress()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient15getLocalAddressEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::getLocalPort()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12getLocalPortEv+0x0): multiple definition of `AsyncClient::getLocalPort()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12getLocalPortEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::remoteIP()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8remoteIPEv+0x8): multiple definition of `AsyncClient::remoteIP()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8remoteIPEv+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::remotePort()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10remotePortEv+0x4): multiple definition of `AsyncClient::remotePort()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10remotePortEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::localIP()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7localIPEv+0x8): multiple definition of `AsyncClient::localIP()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7localIPEv+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::localPort()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9localPortEv+0x4): multiple definition of `AsyncClient::localPort()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9localPortEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::state()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5stateEv+0x0): multiple definition of `AsyncClient::state()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5stateEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::connected()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9connectedEv+0x0): multiple definition of `AsyncClient::connected()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9connectedEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::connecting()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10connectingEv+0x0): multiple definition of `AsyncClient::connecting()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10connectingEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::disconnecting()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13disconnectingEv+0x0): multiple definition of `AsyncClient::disconnecting()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13disconnectingEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::disconnected()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12disconnectedEv+0x0): multiple definition of `AsyncClient::disconnected()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12disconnectedEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::freeable()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8freeableEv+0x4): multiple definition of `AsyncClient::freeable()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8freeableEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::space()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5spaceEv+0x0): multiple definition of `AsyncClient::space()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5spaceEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::add(char const*, unsigned int, unsigned char)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient3addEPKcjh+0x8): multiple definition of `AsyncClient::add(char const*, unsigned int, unsigned char)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient3addEPKcjh+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::write(char const*, unsigned int, unsigned char)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5writeEPKcjh+0x8): multiple definition of `AsyncClient::write(char const*, unsigned int, unsigned char)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5writeEPKcjh+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::write(char const*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5writeEPKc+0x8): multiple definition of `AsyncClient::write(char const*)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5writeEPKc+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::canSend()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7canSendEv+0x4): multiple definition of `AsyncClient::canSend()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7canSendEv+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::ackPacket(pbuf*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9ackPacketEP4pbuf+0x8): multiple definition of `AsyncClient::ackPacket(pbuf*)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9ackPacketEP4pbuf+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::stateToString()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13stateToStringEv+0xc): multiple definition of `AsyncClient::stateToString()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient13stateToStringEv+0xc): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::AsyncServer(IPAddress, unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServerC2E9IPAddresst+0x4): multiple definition of `AsyncServer::AsyncServer(IPAddress, unsigned short)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServerC2E9IPAddresst+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::AsyncServer(unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServerC2Et+0x4): multiple definition of `AsyncServer::AsyncServer(unsigned short)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServerC2Et+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::_s_accept(void*, tcp_pcb*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer9_s_acceptEPvP7tcp_pcbl+0x4): multiple definition of `AsyncServer::_s_accept(void*, tcp_pcb*, long)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer9_s_acceptEPvP7tcp_pcbl+0x4): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::begin()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer5beginEv+0x1c): multiple definition of `AsyncServer::begin()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer5beginEv+0x20): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::end()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer3endEv+0x10): multiple definition of `AsyncServer::end()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer3endEv+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::~AsyncServer()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServerD2Ev+0x8): multiple definition of `AsyncServer::~AsyncServer()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServerD2Ev+0x8): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::setNoDelay(bool)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer10setNoDelayEb+0x0): multiple definition of `AsyncServer::setNoDelay(bool)'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer10setNoDelayEb+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::getNoDelay()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer10getNoDelayEv+0x0): multiple definition of `AsyncServer::getNoDelay()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer10getNoDelayEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::status()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer6statusEv+0x0): multiple definition of `AsyncServer::status()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer6statusEv+0x0): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_close()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6_closeEv+0x20): multiple definition of `AsyncClient::_close()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6_closeEv+0x10): first defined here
/data/radiateur_vincen/.pioenvs/radiateur_vincen/liba52/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::~AsyncClient()':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClientD2Ev+0x24): multiple definition of `AsyncClient::~AsyncClient()'
/data/radiateur_vincen/.pioenvs/radiateur_vincen/libe55/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClientD2Ev+0x28): first defined here
  1. Remove web_server
  2. clean build
  3. Build again
  4. add web server back and build again (no clean this time)
Incidentally, if anyone else lands here with similar errors, I had the same problem when I had both api and mqtt in the same yaml. Removing either allowed it to work. I swear that used to work (though I can’t prove it), but gave the above multiple definitions recently.
Thanks and good indication for Clean Build :smiley: Had not noticed it before and helpful in such situations ! I followed your trick but with api: argument instead of web_server. If I comment it out in code it compiles fine, I put it back in yaml and compilation fails :frowning:
If I do a Clean build on one of my existing nodes that compiled without problems before I have same issue now :frowning: one of my ESPHome libraries damaged ?
Solved for now by switching to dev branch of ESPHome :wink: https://github.com/esphome/issues/issues/683
