Solved - Configuration.yaml does not like 'type'?
Trying to add the GitHub - amaximus/garbage-collection-card: Custom Lovelace card for Garbage Collection custom component
When I paste the following into configuration.yaml
resources:
  //When using HACS installation method
  - {type: js, url: '/hacsfiles/garbage-collection-card/garbage-collection-card.js'}
  //When using manual install method
  - {type: js, url: '/local/garbage-collection-card.js'}
I get the following error? Not sure what I am doing wrong?
bad indentation of a mapping entry at line 93, column 10:
      - {type: js, url: '/hacsfiles/garbage-c ...
Not Sure if the documentation is old but I have it working without the step.
No curly braces.
Same error, does the seem to like “type”?
Remove the comment lines (// …)
And - I recommend using YaML only not mixing it with JSON (although it is valid)
resources:
  - type: js
    url: /hacsfiles/garbage-collection-card/garbage-collection-card.js
