[SOLVED] Configure Sonoff Switch (Tasmota 6.2.1) with mqtt
I just got my first Sonoff switches and flashed them using Tasmota 6.2.1 (higher versions were unstable on WiFi). The switch works fine using the web ui, hassio sees when the switch turns on/off via physical switch or using the Tasmota UI, but I am not able to control it from hassio. My other mqtt devices work like MyQ (Liftmaster Garage and ADT Pulse).
When trying to control the switch, the switch flips but goes back to its original position.
Could anyone give me some guidance of what to check?
configuration.yaml
switch:
  - platform: mqtt
    unique_id: b4e62d33aded
    command_topic: "cmd/heater/power"
    state_topic: "stat/heater/POWER"
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
Had a typo in the command topic…
Should have been cmnd (missed the “n”)
command_topic: "cmnd/heater/power"
