(solved) DarkSky Sensor not loading
edit: my bad. not a darksky issue and not a HA issue. For some reason my automation Pi was missing a default gateway. Been running for months like that, never noticed an issue until now.
Trying to set up some weather forecasting for my homeassistant instance but DarkSky is fighting me…
“sensor:” from configuration.yaml-
  - platform: moon
  - platform: google_travel_time
    api_key: !secret google_api_key
    origin: !secret google_home
    destination: !secret google_work
    name: Drive to Work
    options:
      arrival_time: '07:30:00'
  - platform: darksky
    api_key: !secret darksky_api_key
#    forecast:
#      - 2
    monitored_conditions:
      - summary
#      - icon
#      - temperature
#      - daily_summary
#      - moon_phase
    update_interval: '00:15:00'
From home-assistant.log-
2019-01-09 06:03:02 ERROR (Thread-3) [homeassistant.components.sensor.darksky] Unable to connect to Dark Sky: nPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/apikey/lat/long?units=us&lang=en (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6bdf2ef0>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
2019-01-09 06:03:08 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/discovery.py", line 172, in scan_devices
    results = await hass.async_add_job(_discover, netdisco)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/discovery.py", line 198, in _discover
    netdisco.scan()
  File "/srv/homeassistant/lib/python3.5/site-packages/netdisco/discovery.py", line 63, in scan
    self.gdm.scan()
  File "/srv/homeassistant/lib/python3.5/site-packages/netdisco/gdm.py", line 22, in scan
    self.update()
  File "/srv/homeassistant/lib/python3.5/site-packages/netdisco/gdm.py", line 79, in update
    sock.sendto(gdm_msg, (gdm_ip, gdm_port))
OSError: [Errno 101] Network is unreachable
I’ve gone through my yaml, i’ve tried breaking stuff on purpose to see if /that/ comes before or after the darksky fault… I’ve checked my API usage on the darksky dev chart, i’ve reset my api key… thoughts?
(I really hope my formatting comes out right)
I’m fighting the same issue. How did you define the default gateway? Is this a configuration.yaml thing?
Many thanks!!
To help anyone else with the same issue…
sudo route add default gw (router IP)
is the command that I used. Not sure this is a perfect fix as Im not sure it persists after a reboot, but it gets things working for me with my current setup.
