I have a garden watering automation setup which activates when a user switches the pump on.
The automation waits for a duration (say 40mins) then will play a notification sound and turn off the pump.
The issue I have is that if the user turns the pump off before the time is complete, the notification will still play.
I assume the condition should fix this, but I cant get it working right…
- id: '1606285797602'
alias: Bore Timer
description: ''
- platform: state
entity_id: switch.bore_power_switch
to: 'on'
condition:
- condition: state
state: 'off'
- delay: 00:{{ states('input_number.bore_timer') | int }}
- type: turn_off
device_id: 45e70ee430558d7eb7d4d374eba77bd6
domain: switch
- service: script.chime_bore_off
data: {}
- service: shell_command.speak_bore
data: {}
- service: shell_command.notification_bore
data: {}
mode: single
