i’ve just installed Hassio on docker on RPi4 using the 64bit architecture, following this tutorial https://www.home-assistant.io/hassio/installation/#debianubuntu
Now i can’t access home assistant throught it’s ip:port
as i get the error: ERR_CONNECTION_REFUSED
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
************ homeassistant/armv7-hassio-dns:1 "coredns -conf /conf…" 4 minutes ago Up 4 minutes hassio_dns
************ homeassistant/armv7-hassio-supervisor "/bin/entry.sh pytho…" 15 minutes ago Up 5 minutes hassio_supervisor
The logs of the supervisor container are revealing the following:
The * in the ip’s are numbers.
19-12-19 19:13:54 INFO (MainThread) [__main__] Initialize Hass.io setup
19-12-19 19:13:54 INFO (MainThread) [hassio.docker.network] Can't find Hass.io network, create new network
19-12-19 19:13:55 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 193
19-12-19 19:13:55 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-12-19 19:13:55 INFO (MainThread) [__main__] Setup HassIO
19-12-19 19:13:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-12-19 19:13:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-12-19 19:13:56 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
19-12-19 19:13:56 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
19-12-19 19:13:56 INFO (MainThread) [hassio.host.info] Update local host information
19-12-19 19:13:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-12-19 19:13:56 INFO (MainThread) [hassio.host.services] Update service information
19-12-19 19:13:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-12-19 19:13:56 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-12-19 19:13:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-12-19 19:13:56 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}19-12-19 19:13:56 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-12-19 19:13:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-12-19 19:13:56 INFO (MainThread) [hassio.dns] No CoreDNS plugin Docker image homeassistant/armv7-hassio-dns found.
19-12-19 19:13:56 INFO (MainThread) [hassio.dns] Setup CoreDNS plugin
19-12-19 19:13:56 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/armv7-hassio-dns tag 1.
19-12-19 19:14:05 INFO (MainThread) [hassio.dns] CoreDNS plugin now installed
19-12-19 19:14:05 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-12-19 19:14:05 WARNING (MainThread) [hassio.dns] Ignore invalid DNS Server: dns://fd00::e228:****:****:****
19-12-19 19:14:05 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-12-19 19:14:05 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.*.*
19-12-19 19:14:09 INFO (SyncWorker_5) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1
19-12-19 19:14:09 INFO (MainThread) [hassio.homeassistant] No Home Assistant Docker image homeassistant/raspberrypi4-64-homeassistant found.
19-12-19 19:14:09 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
19-12-19 19:14:09 INFO (SyncWorker_2) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-64-homeassistant tag landingpage.
19-12-19 19:14:18 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-12-19 19:14:18 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-12-19 19:14:18 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 62 new - 0 remove
19-12-19 19:14:18 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-12-19 19:14:18 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-12-19 19:14:18 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-12-19 19:14:18 INFO (MainThread) [hassio.discovery] Load 0 messages
19-12-19 19:14:18 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-12-19 19:14:18 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 0
19-12-19 19:14:18 INFO (MainThread) [__main__] Run Hass.io
19-12-19 19:14:18 INFO (MainThread) [hassio.api] Start API on 172.30.*.*
19-12-19 19:14:18 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-12-19 19:14:18 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-12-19 19:14:18 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-12-19 19:14:20 INFO (SyncWorker_4) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-64-homeassistant with version landingpage
19-12-19 19:14:26 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
19-12-19 19:14:26 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-12-19 19:14:26 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-12-19 19:14:26 INFO (MainThread) [hassio.core] Hass.io is up and running
19-12-19 19:14:26 INFO (MainThread) [hassio.homeassistant] Setup Home Assistant
19-12-19 19:14:26 INFO (SyncWorker_15) [hassio.docker.interface] Update image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:0.103.2
19-12-19 19:14:26 INFO (SyncWorker_15) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-64-homeassistant tag 0.103.2.
19-12-19 19:16:19 INFO (SyncWorker_15) [hassio.docker.interface] Clean homeassistant application
19-12-19 19:16:19 INFO (MainThread) [hassio.homeassistant] Home Assistant docker now installed
19-12-19 19:16:19 INFO (MainThread) [hassio.homeassistant] Start Home Assistant
19-12-19 19:16:22 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-64-homeassistant with version 0.103.2
19-12-19 19:16:27 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
19-12-19 19:16:27 ERROR (MainThread) [hassio.homeassistant] Can't start Home Assistant!
19-12-19 19:16:27 INFO (SyncWorker_6) [hassio.docker.interface] Cleanup images: ['homeassistant/raspberrypi4-64-homeassistant:landingpage']
19-12-19 19:24:24 INFO (MainThread) [__main__] Stopping Hass.io
19-12-19 19:24:24 INFO (MainThread) [hassio.api] Stop API on 172.30.*.*
19-12-19 19:24:24 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding
19-12-19 19:24:24 INFO (MainThread) [hassio.core] Hass.io is down
19-12-19 19:24:24 INFO (MainThread) [__main__] Close Hass.io
19-12-19 19:24:49 INFO (MainThread) [__main__] Initialize Hass.io setup
19-12-19 19:24:49 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 193
19-12-19 19:24:49 INFO (MainThread) [__main__] Setup HassIO
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-12-19 19:24:49 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
19-12-19 19:24:49 INFO (MainThread) [hassio.host.info] Update local host information
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-12-19 19:24:49 INFO (MainThread) [hassio.host.services] Update service information
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-12-19 19:24:49 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-12-19 19:24:49 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}19-12-19 19:24:49 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-12-19 19:24:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-12-19 19:24:49 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
19-12-19 19:24:49 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-12-19 19:24:49 WARNING (MainThread) [hassio.dns] Ignore invalid DNS Server: dns://fd00::e228:****:****:****
19-12-19 19:24:49 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-12-19 19:24:49 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.*.*
19-12-19 19:24:49 INFO (SyncWorker_1) [hassio.docker.interface] Clean hassio_dns application
19-12-19 19:24:51 INFO (SyncWorker_1) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1
19-12-19 19:24:51 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/raspberrypi4-64-homeassistant with version 0.103.2
19-12-19 19:24:52 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-12-19 19:24:52 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-12-19 19:24:52 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 62 new - 0 remove
19-12-19 19:24:52 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-12-19 19:24:52 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-12-19 19:24:52 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-12-19 19:24:52 INFO (MainThread) [hassio.discovery] Load 0 messages
19-12-19 19:24:52 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-12-19 19:24:52 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 0
19-12-19 19:24:52 INFO (MainThread) [__main__] Run Hass.io
19-12-19 19:24:52 INFO (MainThread) [hassio.api] Start API on 172.30.*.*
19-12-19 19:24:52 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-12-19 19:24:52 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-12-19 19:24:52 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-12-19 19:24:52 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/raspberrypi4-64-homeassistant
19-12-19 19:24:58 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
19-12-19 19:24:58 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-12-19 19:24:58 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-12-19 19:24:58 INFO (MainThread) [hassio.core] Hass.io is up and running
Logs of the hassio container:
.:53
2019-12-19T20:24:52.390+01:00 [INFO] CoreDNS-1.6.1
2019-12-19T20:24:52.397+01:00 [INFO] linux/arm, go1.12.7, 1fda570
CoreDNS-1.6.1
2019-12-19T20:24:52.665+01:00 [INFO] 172.30.*.*:* - 38170 "AAAA IN version.home-assistant.io. udp 43 false 512" NOERROR qr,rd,ra 149 0.023192297s
2019-12-19T20:24:52.665+01:00 [INFO] 172.30.*.*:* - 37133 "A IN version.home-assistant.io. udp 43 false 512" NOERROR qr,rd,ra 125 0.023251592s
Thank you for your support
