Setup: In short ESPHome device, made of WS2812B LED strip. 50 pixels in summary, split in 5x10 pixels via partition platform. Proudly made by me
This is the ESPHome configuration:
esphome:
esp8266:
board: esp01
logger:
api:
wifi:
ssid: !secret wifi_ssid
e131:
method: multicast
light:
- platform: neopixelbus
variant: WS2812X
pin: GPIO0
num_leds: 50
name: "Bottle Lights Complete"
type: GRB
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_rainbow:
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_fireworks:
variant: WS2812X
pin: GPIO15
num_leds: 10
type: GRB
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
- platform: partition
segments:
- id: strip
to: 49
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
segments:
- id: strip
to: 39
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
segments:
- id: strip
to: 29
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
segments:
- id: strip
to: 19
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
segments:
- id: strip
to: 9
effects:
- e131:
universe: 1
channels: RGB
- random:
- pulse:
- strobe:
- flicker:
- addressable_scan:
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
inverted: True
name: "Bottle Lights Button"
on_click:
- min_length: 5ms
max_length: 1000ms
then:
- if:
condition:
light.is_on: strip
then:
- light.turn_off:
- if:
condition:
light.is_off: bottle4
then:
- light.turn_on:
effect: "flicker"
else:
- light.turn_off: bottle4
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- if:
condition:
light.is_off: bottle2
then:
- light.turn_on:
effect: "flicker"
else:
- light.turn_off: bottle2
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- if:
condition:
light.is_off: bottle5
then:
- light.turn_on:
effect: "flicker"
else:
- light.turn_off: bottle5
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- if:
condition:
light.is_off: bottle3
then:
- light.turn_on:
effect: "flicker"
else:
- light.turn_off: bottle3
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- if:
condition:
light.is_off: bottle1
then:
- light.turn_on:
effect: "flicker"
else:
- light.turn_off: bottle1
- min_length: 1001ms
max_length: 3000ms
then:
- if:
condition:
light.is_on: strip
then:
- light.turn_off:
- light.turn_on:
brightness: 100%
red: 100%
green: 84%
blue: 38%
effect: "flicker"
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- light.turn_on:
brightness: 100%
red: 100%
green: 84%
blue: 38%
effect: "flicker"
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- light.turn_on:
brightness: 100%
red: 100%
green: 84%
blue: 38%
effect: "flicker"
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- light.turn_on:
brightness: 100%
red: 100%
green: 84%
blue: 38%
effect: "flicker"
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- light.turn_on:
brightness: 100%
red: 100%
green: 84%
blue: 38%
effect: "flicker"
- min_length: 3001ms
max_length: 10000ms
then:
- if:
condition:
light.is_on: strip
then:
- light.turn_off:
- homeassistant.service:
service: script.bottle_lights_random_color
The idea is that I would have 5 separate “bottle entities” (Bottle 1, 2, 3, 4 and 5) which would be controlled with one dummy entity (Bottle Lights). “Bottle Lights” is “connected” to GPIO15. GPIO15 is not exist on ESP01S module, so as said, it is dummy. It’s purpose is only to have it inside HA as light entity, so I can turn it on/of, change color, etc. and transfer it’s value to every separate bottle via automation, with 1 second delay between bottles.
Not important for current situation, but just to explain: “Bottle Lights Complete” is whole strip, all 50 pixels, and it is controlable directly from HA. This is something I will need later.
Ok, as said, the idea is that I change color or brightness or effect on dummy “Bottle Lights” entity, then automation should apply same color/brightness/effect values from “Bottle Lights” to “Bottle 5”, wait 1 second, apply to “Bottle 2”, wait 1 second, etc. all 5 bottles.
This is the automation:
- id: '1652174226030'
alias: Bottle Lights Dummy
description: ''
- platform: state
entity_id: light.bottle_lights
attribute: brightness
- platform: state
attribute: rgb_color
- platform: state
to: 'on'
- platform: state
to: 'off'
- platform: state
attribute: effect
condition: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- service: light.turn_on
data_template:
rgb_color: '{{ state_attr(''light.bottle_lights'', ''rgb_color'') }}
brightness: '{{ state_attr(''light.bottle_lights'', ''brightness'') }}
effect: '{{ state_attr(''light.bottle_lights'', ''effect'') }}
entity_id: light.bottle_5
- conditions:
- condition: state
state: 'off'
sequence:
- service: light.turn_off
default: []
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data_template:
entity_id: light.bottle_2
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data_template:
entity_id: light.bottle_3
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data_template:
entity_id: light.bottle_1
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data_template:
entity_id: light.bottle_4
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
Everything is working like a charm, except when I’m playing with effects. If I change the effect on dummy “Bottle Lights” entity, this is also ok - new effect will be applied on all 5 bottles, second by second. But if turn off the effect on dummy entity, i.e. set effect to None, then nothing happens. Basically, if I turn on any effect via dummy entity, it is not possible switch back to None any more, I can only switch between effects (of course, I can switch to None via each single entity lovelace card - Bottle 1, 2, 3…)
Is it possible that automation cannot be triggered if some state has been changed to “None”?
Sorry for long post, I was try to explain best I can. Thanks in advance, if you need any additional info…
