I am using lots of Shelly devices and switchs. I sucessfully integrated them all into my Homeassistant dashboard. No problems. Now some of them appear as “Unavailable”. The Shelly cloud shows them as active and I can switch them without any problems (left image). So the devices are online but Homeassistant insitst that they are not availabe (right image). I am new to homeassistant and would really appreciate some pointers.
Which integration did you use to add them?
What model Shelly device?
All shelly deices were recognized during Home Assistant’s setup. All Shelly IoT-Devices are running in the WLAN and all have their own IP-Adress. When I look in the integrations used by my various devices there is a Shelly tile. So I guess it is the Shelly Integration.
Currently the devices affected are:
3x Shelly Dimmer 2 (dimmer)
1x Shelly 2.5 (double switch)
1x Shelly 1 (single switch)
Not affected are
5x Shelly Dimmer 2
1x Shelly 2
1x Shelly Plug
2x Shelly 1
SOLUTION.
Reinstall and start from scratch. Works a treat. All online Shelly Devices appear as online in Home Assistant now too.
Did you have any problem again?
